Rotopax fuel tank opinions - Defender Source
Old April 24th, 2012, 12:14 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
delete please
Anyone out there using the Rotopax tanks? I am thinking about replacing the metal can I have since it is rusting away. Any opinions from someone that has used them?
Old April 24th, 2012, 07:37 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I do and they are great....be careful on the spouts. You can get the "old fashion spouts", but I belive they all come with the new low emission spouts now. They are a little trickey to learn to use and you end up wasting a little fuel working out a system to get fuel from the can to the tank.
I just took the spout apart. I have rotopax for diesel, petrol and water and I use their rack system.
Old April 24th, 2012, 12:10 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I use them exclusively now, both the fuel and water cans. I love how I can stack and configure them how I want. I use the 2 gal cans.
Semper Fi!
Old August 21st, 2013, 02:44 PM
apierce
Adam Pierce
'95 D90 ST #2395
Reviving this thread because while i like the design and mounting capabilities, i have had repeated issues with the spouts. The spring used to open the "eco" spouts broke on me twice - both times on first use. Anyone else experience similar issues or a can offer a solution here? Am i possibly doing something wrong? The tanks are worthless without the spouts, but too expensive to keep replacing... Any help / commiseration would be much appreciated.
Old August 21st, 2013, 03:54 PM
Ray_G's Avatar
Ray_G
Ray Gerber
As Jeff suggests, I'm not going to advocate going outside the CARB regs and the good people of the EPA...but partnered with the water spout they work well (allegedly...as I'd never do that mind you...bad for the environment).
Rotopax are fantastic.
r-
Ray
fuel, fuel tank
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Opinions on Fuel Tank Vendors ajh Defender Technical Discussions 11 January 28th, 2009 12:26 PM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
