Rotella T 15W-40 - Defender Source
Old January 18th, 2009, 01:45 PM
Grover's Avatar
Grover
Question Rotella T 15W-40
Your thoughts about using this oil in a 3.9L?
Cheers...
Old January 18th, 2009, 03:45 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Keeps them from gunking up, I use it in my 193k '91 RRC.
Old January 18th, 2009, 03:50 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Same here. Just make sure to still keep the changes regular, I do a change whenever I see the pressure start dropping.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 18th, 2009, 04:01 PM
People like it at the Discoweb... Seems to be good for our motors.. Ive started using it in the RRC, I might go back to the mobil one
Old January 19th, 2009, 02:30 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Discoweb thread on oil to use in rover engines: http://www.discoweb.org/forums/showthread.php?t=54420 (and some followup here http://www.discoweb.org/forums/showt...ht=oil+rotella with more actionable brand/oil details)
The original thread is very interesting, but at the end, I could still not list oils I should be using without further research (and likely printing the entire thread when going to the local oil shop), second thread is less detailled but at least provide simple information for us to use.
I figured that could be useful to all of us (and me when I decide it is time to do my own oil changes....).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 19th, 2009, 04:24 PM
I just started using the Rotella T 15W-40 in my 3.9L and so far so good.
Old January 19th, 2009, 08:04 PM
When its really chilly out I notice the oil light stays on a little longer at start up.
Old January 19th, 2009, 08:12 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I've been using it for years in my D90 with good success. I recommend it.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 20th, 2009, 07:55 PM
Grover's Avatar
Grover
Thumbs up
Since Rotella T 15W-40 is a diesel oil, can it cope with the higher heat given off by a gas V8? I've read forums about it, and lots of Disco owners like it. What I find interesting is the forums state this oil has high temp/high shear properties as required for diesel engines, and our flat tappet 3.9L V8's can benefit from this property. I am questioning if there are any chance this oil could damage the catalyst over time. As far as oil change intervals, I would NEVER go beyond 3month/3k miles. It seems just about everybody has their own reasons for using specific oil brand//types.
Cheers...
Old January 20th, 2009, 07:59 PM
"I am questioning if there are any chance this oil could damage the catalyst over time."
In theory, yes. In practice, no.
I used the 5w40 synthetic in my disco but switched back to mobil one because the rotella caused a bit of lifter chatter on startup.
Old January 20th, 2009, 08:28 PM
Cheers...
You obviously have no idea how hot turbo chargers get. If you are religious about changing your oil then you should be fine with whatever you are using. I would not use anything less than x/40 in my truck. I dont see how motor oil could hurt the CAT's but maybe I need to read a little more. I think the Rotella is fine for these trucks, it is hard to argue with the facts. The "evac system" is also important to the well being of Rover V8's so there is a little more to longevity than oil changes. Post up and read a little more on the D-Web a lot of good information on that BB.
I dont like the Rotella because I have to look at the oil pressure light for at least 4 seconds when I start up on a cold morning (~20degrees)....
Are you using the 0w40?
Apples and Oranges, he likes the Royal Purple I like the Redline.
Old January 20th, 2009, 09:19 PM
Sergeant_V's Avatar
Sergeant_V
Abel Villesca
1995 D-90 ST
Ditto
Wobble over 40 mph smob Defender Technical Discussions 8 October 31st, 2009 11:06 AM
D90 - SD Cross Bar Screws - M8 1-25 (40)? pcscharfe Defender Technical Discussions 10 May 24th, 2009 06:29 AM
where to buy Rotella 5W40, in Mass artm Defender Technical Discussions 7 December 7th, 2008 06:33 PM
Samsung 40 in. 1080p LCD at Sears for $999 until 5/31 themaxx The Flea Market 1 May 21st, 2008 06:33 PM
Mobil 1 vs. Rotella rover4x4 Misc. Chit-Chat 3 April 21st, 2008 06:17 PM
