Rotary Lift - Defender Source
Old August 29th, 2006, 02:32 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Rotary Lift
We bought a two post rotary lift for our garage last week (chassis type). I cant wait to get up undereath the 90 and see what's leaking.
I have looked in our "Vehicle Lifting Guide" and it says that there is no safe way to lift the Defender without using a drive on type lift. I lifted it up the other day using the lifts frame support arms and it seemed fine. Anyone lift owners have any advice?? I would hate to have an accident.
Old August 30th, 2006, 03:03 PM
pendy's Avatar
pendy
jim pendleton
89'd90
If you promise to send me a LR toy of some sort I will post some pictures of how I set up a d90 on my two post lift. Watcha got?
JP
legend in my own mind
Old August 30th, 2006, 03:21 PM
It is not hard, just make sure that there is not crap/undercoat on the bottom of the frame, they like to slip . . .
Old August 30th, 2006, 03:34 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
On my friend's 2 post lift, I put the front pads underneath the retangular bracket near the sway bar mounts. On the rear, I put the pads underneath the trailing arm mount shroud. Did this many times, seems alright to me.
Old August 30th, 2006, 08:25 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
JP
Not much, but I will owe you a toy and when I see one I'll send it to you! I actually think I figured it out, but you might have a better idea than me. For the rear, I put the lift supports on the frame right behind where the trailing links attach to the frame.
For the front, I put the lift supports right inside the three sided rectangle looking thing that is part of the frame (right behind the front links).
Does this make sense?
Also, do you guys run without swaybars? I had them off for a while and then put them back on a while back. I don't think I can tell a bit of difference.
Old September 13th, 2006, 12:52 PM
pendy's Avatar
pendy
jim pendleton
89'd90
As promised.
ID:	6686   Click image for larger version
Old September 13th, 2006, 02:51 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Thanks! I figured it out, but I will get you a toy when I can!
Old September 14th, 2006, 03:51 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Sometime when we get to grab a beer together then.
Be safe with the lift.
JP
Actual lift measurement with OME KevinNY Defender Technical Discussions 1 February 2nd, 2006 04:18 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
Hi lift mounted on Roll Cage Oggy Defender Technical Discussions 6 May 25th, 2004 11:27 AM
