Roof side seals for old 90 - Defender Source
Old June 10th, 2016, 02:00 PM
jafir's Avatar
jafir
Jafir Elkurd
So the catalogs show the roof side seals between the tub sides and the roof sides are different for old 90s and newer 90s..... but are they really?
The old stuff shows to be one part for both sides MUC1333, S/S to AML710060/AML710070, different for each side.
The newer stuff shows to be ALR5056, one part for both sides again.
Is there any reason these are different? Or can I used the newer seal on my older 90? I do know that the tub cappings on the old 90s aren't one piece like they are on the new 90s. Maybe they made the older seals different to fill this gap?
Old June 10th, 2016, 02:29 PM
Hey Jafir,
On my 1984 Station wagon, the upper van side seals are LR053839 (Left) and LR053838 (Right). These are not interchangeable (sided).
Regarding the lower seals:
I've attached the part numbers of the defender lower van side waist seals. Note that there are a lot of numbers and none are cheap.
On my truck, which is a 1984, Mike (my truck's PO) used PN 333487, which is the Series lower seal and in addition to being cheaper, is also non-sided, meaning you can use the same part for both left and right.
Old June 10th, 2016, 03:11 PM
jafir's Avatar
jafir
Jafir Elkurd
My VIN is even lower, so mine would be those that say to EA instead of the from FA.
So basically I can use whatever I want? I like that idea.
Old June 10th, 2016, 06:05 PM
I definitely would recommend 333487 instead of any of the Defender options. It's a very, very robust seal.
Old June 10th, 2016, 06:07 PM
jafir's Avatar
jafir
Jafir Elkurd
Good to know! Thanks!
90, d 90, roof, seals
Our 8 year old dog bit our 2 year old daughter... hillstrubl Misc. Chit-Chat 62 July 8th, 2014 12:31 PM
Two Bottles Old Rip Van Winkle 10 year old $250 each evilfij The Flea Market 6 January 4th, 2014 10:21 AM
fiberglass hardtop side seals needed. JKC Wanted 1 September 29th, 2013 02:56 AM
fiberglass hardtop side seals needed. JKC For Sale - Parts 0 October 24th, 2012 01:31 PM
TD5 bulkhead vent seals vs. NAS seals Tyler Wirken Defender Technical Discussions 11 March 14th, 2011 10:22 PM
