Roof seals - Defender Source
Old February 26th, 2015, 09:49 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Roof seals
So when I dip the 110 I figure it's a good time to replace my leaking roof to windshield seal. Since I'll be pulling the roof anyways. That I found a part # for.
Is there any seal material between the roof and the sides? If not is there something you guys are using to seal it up?
I didn't find a part number for this so I'm open to any ideas.
Unknown Author
716-898-8153
Old February 26th, 2015, 09:54 PM
Dip the 110 ?
Old February 26th, 2015, 10:00 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Plasti-dip Doug we talked about it at Romp.
Unknown Author
716-898-8153
Old February 26th, 2015, 10:13 PM
Yeah but I was drinking like a fish....what color you going with ?
Old February 26th, 2015, 10:34 PM
the roof has two special l-shaped rectangular seal made of foam rubber that sits between the roof and sides.
Old February 26th, 2015, 10:48 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Not sure but so far one of the charcoal gray pearls is in the lead. I posted a thread on here to let the forum decide. Satin black I think is also a top runner.
Don't suppose you know where I can find it.
Unknown Author
716-898-8153
Old February 27th, 2015, 12:06 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
I got mine from rovers north. RDS probably has them also
Old February 27th, 2015, 08:00 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Yes RN or call Roverfarm. I replaced all my seals when I had my roof off. Also when I was replacing my front window seal, I ran into trouble and had a guy that specialized in older installs come to my house, he was cheap. If you want his number I think I may still have it.
1983 ROW D110
1970 Series III (Parting out)
Old February 27th, 2015, 08:40 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
I'd would like his number, I want to do the windshield seal as well but I'm not confident I can do it without cracking the glass.
I'll check Rovahfarm again, I must have missed it.
Unknown Author
716-898-8153
Old February 27th, 2015, 09:58 AM
usadventureracing
Brett
110
I always call Trevor, much easier.
------ Follow up post added February 27th, 2015 11:02 AM ------
Auto Glass Techniques 1-847-428-3941
1983 ROW D110
Old February 27th, 2015, 11:01 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
thanks!
Unknown Author
716-898-8153
Old February 27th, 2015, 11:40 AM
Confess I reused old seals and so far so good.
The problem could be worse....and have a seal go inside your truck
Old February 27th, 2015, 12:12 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
I reused the heavy seals at the bottom roof and sides. I replaced the seal between the windscreen frame and bulkhead, the windscreen seal itself, and the little squares at the corners of the windscreen and the roof. I used Britparts on them.
A lot of people cry about the windscreen seal, and how the seal seems to be the incorrect size and they broke the glass trying to install it. I can tell you one thing with certainty; you NEED TWO PEOPLE to install it correctly using the string method and a lot of lubricant. Mine fit perfect but was a lot of swearing for about 45 minutes.
Old May 26th, 2015, 07:24 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
Does anybody have a part number for these? I'm at the same part in my life.
------ Follow up post added May 26th, 2015 05:29 PM ------
It's the same part for a 90 SW too I'd assume:
SEAL RH ROOFSIDE-ROOF DEFENDER 90, RNF539, MXC3676 - Rovers North - Classic Land Rover Parts
and
SEAL LH ROOFSIDE-ROOF DEFENDER 90, RNF539, MXC3677 - Rovers North - Classic Land Rover Parts
Old May 26th, 2015, 07:31 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Brandon, you'll need:
LR053839 - Window Side Gasket, LH Upper
LR053838 - Window Side Gasket, RH Upper
ALR5055 - Window Side Gasket, Lower (these aren't handed like the uppers)
-Ash
Geared Restoration Co.
352-572-3236
Old May 26th, 2015, 07:41 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
I had no problem using self adhesive household weather strip. $5. Though it would seem most of you are trying to keep them concours ready. caulk strip would work too if you don't remove it much. Nothing special at all.
Hardly anything on the rover is "rover" its not that interesting or large a company. So many generic parts on these things.
Old May 26th, 2015, 07:54 PM
curry's Avatar
curry
brandon curry
Series 1 and 110.
-Ash
Thanks. Anybody know if there are non-OEM options out there?
Old May 26th, 2015, 07:57 PM
DefenderMd's Avatar
DefenderMd
Ben
You're talking about between the top.. the white thing with the rain gutters.. and the sides.. usually with windows.. bolts to the top of the bed rail?
Its a flat thing to a flat thing that isn't exposed to gravity fed water. Any and all seals will work.
roof, seals
TD5 bulkhead vent seals vs. NAS seals Tyler Wirken Defender Technical Discussions 11 March 14th, 2011 10:22 PM
Nas 110 cage seals that go on roof bjf For Sale - Parts 3 September 29th, 2010 12:58 PM
Seals between windshield frame and bulkhead and roof bjf Wanted 7 May 18th, 2009 06:20 PM
Seals for D90 Hardtop Sides to Roof. evilfij Wanted 1 April 4th, 2009 11:45 AM
Questions about replacing hub seals... discobro Defender Technical Discussions 5 June 5th, 2004 12:07 PM
