roof replacement tips, advice - Defender Source
Old October 16th, 2011, 01:45 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
My new roof finally arrived and I am hoping to get all the seals I need by next weekend so I can do the swap. Are there any tricks or little things I should know ahead of time to make this easier? It is a new style 110 roof with sunroof and alpine windows.
Thanks, Jason
Old October 16th, 2011, 01:54 PM
When we put the roof on JimC's 110 the rubber seal was a little tricky ... make sure everything is warm ... it will help manipulate the seal. If you end up with folded sections a metal scraper used gently can be used to tease the seal into place.
A small amount of washing up liquid in water may also help manipulate the seal.
Old October 16th, 2011, 08:08 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Do most all the bolts hand tight, if not all of them. Then tighten everything up.
Land Rover 110
Old October 16th, 2011, 08:18 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Get new fasteners. Nylocks are nice.
1970 SIIA 88, Sold
Old October 16th, 2011, 09:18 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Has anyone put in the alpine windows themselves or is this something I should have a glass guy do?
Old October 17th, 2011, 12:05 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Are the holes there already?
If so it is pretty easy. If you have to cut the holes if you had a template that would certainly make it easier.
Old October 17th, 2011, 02:43 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
the holes are all cut. I am just worried about them leaking if I screw something up
Old October 17th, 2011, 03:00 PM
They are easy, unlike the windscreen. Two piece seal makes it easy.
ac, roof
Tips in SW Roof and Side removal?? KKilo23 Defender Technical Discussions 2 October 9th, 2009 11:20 PM
Jump seat cardboard replacement advice GaryBaxter Defender Technical Discussions 5 August 14th, 2007 02:57 PM
Headlamp replacement, advice btate Defender Technical Discussions 4 April 3rd, 2006 03:38 PM
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
Humor the ST aluminum roof dream... thecatsmeow Defender Technical Discussions 30 October 5th, 2004 08:31 PM
