Roof Rack Mounting - Defender Source
Old June 7th, 2011, 08:50 AM
NoVaKevin
Kevin
sold#1469
Thumbs down Roof Rack Mounting
Im going to mount my roof rack sometime this weekend.
Is there anywhere that sells like a sheet of rubber that I can use to make a gasket between the ladder mounting plate and where it attaches to the body? Also, for where the feet attach to the cage? I do not want to screw up the paint. Any suggestions?
Anyone have a mounting diagram or picture for an SD roof rack (I have a custom made rack but appears to be modeled after SD one) ? Specifically, where it attaches around the badge/tire carrier area. I have no instructions, and have one extra bracket that is the exact same design as the one attached to the ladder where it bolts to the tire carrier area.
Old June 7th, 2011, 08:52 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
if you cant find a sheet of rubber, cut up a bicycle tube
Old June 7th, 2011, 09:05 AM
NoVaKevin
Kevin
sold#1469
good call on the tire tube.
i found this.... http://www.eastcoastrover.com/SafetyDevices.html
in the diagram of the cage, which lists the parts.....
there are 3 brackets external to the ladder...2 long and skinny on left, 1 big on right......do they go on the inside of the tub?
Old June 7th, 2011, 09:27 AM
Originally Posted by NoVaKevin View Post
"1x rear ladder/support system with 3x backing plates"
Yes.
Old June 7th, 2011, 09:32 AM
Naplm00
Matthew
Tractor supply sells sheet rubber in thicknesses from 1 mil all the way up to 1/4 in thick for bed liners. Cheap too
Old June 7th, 2011, 09:33 AM
Swimming pool liner - find a supply shop and get some 'samples'
ac, mount, rack, roof, roof rack
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
roof rack swap RiMiD814 For Sale - Parts 2 March 5th, 2006 12:04 AM
Roof rack question... oldscratchggf Defender Technical Discussions 7 February 10th, 2006 02:44 PM
Custom Rovers North D90 Roof Rack Barnett Childress For Sale - Parts 0 October 9th, 2005 07:29 AM
FS/FT RoversNorth roof rack Hans For Sale - Parts 6 May 8th, 2004 07:22 AM
