roof rack and a hannibal roof tent on a ST 90? - Defender Source
Old March 15th, 2009, 11:00 PM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
Does anyone have any experience to share on putting a Hannibal 1.4 roof tent on a D90 Soft top with a SD roof rack?
Old March 16th, 2009, 08:08 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yes.
a) Remove the basket and mount custom cross bars
b) Modify SD basket
c) Have new basket built to custom fit.
d) Mount tent to top of basket.
I would recommend all but "d". Search the archives for many posts on the subject.
Old March 16th, 2009, 08:30 PM
DonFromWhitby
Don Andrews
Originally Posted by dmarchand
Yes.
b) Modify SD basket
I was considering cutting a section of the roof rack to make room for the swing part of the roof tent?
Old March 17th, 2009, 07:58 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
If it is the SD basket, I personally would not (and did not). I had a new basket made specifically for it (that included mounts for the awning on either side). But it would work. My only thought going that route is you are cutting into a structural component of the basket. You'll need to find a way to reinforce either side of the opening so the basket doesn't fold in if you lean it on a tree or otherwise.
Old March 17th, 2009, 08:01 AM
DonFromWhitby
Don Andrews
Yes, it is the SD basket... Not sure about having a custom one made... I suppose I could remove just the basket part of the rack, leaving me to figure out how to suspend it properly over the soft top...?
Old March 17th, 2009, 08:23 AM
I had an old rack that was already tweaked, so I cut the front off and was not happy with that arrangement - there is no really good place to cut and have a result that looks good. It worked for a while but I went with the custom rack as soon as it was practical. Mounting a couple bars instead of the rack I think is a good solution, and you could even use the extra distance to put a platform of some kind up there so you had a little flat space behind your tent. I really don't like the idea of mounting the tent above the top rail of the rack.
Old March 17th, 2009, 09:02 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
just so you can compare:
Here is a factory basket cut for a tent
http://www.eastcoastrover.com/99.html
Email:
90, ac, nib, rack, roof, roof rack
