Roof Cantrail Bolt Size - Defender Source
Old November 22nd, 2006, 06:43 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Can anyone tell me the size of the bolt that is used to secure the leading corner of the roof to the windscreen? The parts manual simply describes this part as "screw" and lists it as p/n AB614081L.
Old November 22nd, 2006, 09:03 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
it is a 6mm bolt...on a soft top they are beefy phillips head screws, but to make it mountable in a hardtop you should use a bolt...6mm, guaranteed.
George
Old November 23rd, 2006, 06:21 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
yup a 6mm (M6) bolt. i stacked like 2 washers then screwed the bolts on. the washers give the bolt head a little lift so you can get a wrench in there to tighten it down and losen it up when needed. if you dont give the bolt some lift its hard to get at it because it is sunken down inside. this is for a hardtop at least
roof
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
Bolt & nut size? Berty Defender Technical Discussions 7 June 3rd, 2004 06:26 AM
