Rollcage Light Install - Defender Source
Old January 8th, 2011, 12:52 AM
RoverNC's Avatar
RoverNC
James Wortman
1994 D90 #1693
I am in the process of installing 4 Hella 4000's on my rollcage and it looks like the most user-friendly option is to ziptie down the inside of the cage. I'm left with deciding where to run the wires through to the cab. Any advice / experiences on the best location?
Old January 8th, 2011, 01:07 AM
manchester
sloan
1994 D90 ST and 1997 D90 ST
Hella installation
Mine were installed professionally. I can send you info when I get to my garage and look how they ran everything!
Old January 8th, 2011, 12:16 PM
specops1526's Avatar
specops1526
Beluga '97 90
Don't drill into the cage. You'll be inviting rust in. I believe most people zip tie them to the cage and then down into the engine bay.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old January 8th, 2011, 12:58 PM
RoverNC's Avatar
RoverNC
James Wortman
1994 D90 #1693
Much appreciated. I don't need to tame any more rust issues and the zip ties look like they'll do the job just fine.
Old January 8th, 2011, 05:53 PM
smack,whack, crack!
Old January 9th, 2011, 11:45 PM
blenkush's Avatar
blenkush
Severin Blenkush
97 D90 LE, 10 Lotus Exige S, 05 LR3
zip tie method
I concur about not drilling the cage. I put 4 lights on the cage and ran the wires down the inside of the A pillar behind the plastic trim. On the hard top, there's a slot under the weather strip around the door that the wires just squeezed into. Dressed the outside up with some of that grooved plastic stuff you can get at a stereo shop. It's been in place almost 10 years with no issues.
Cheers,
Severin
ID:	34672   Click image for larger version
Old January 10th, 2011, 12:00 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Bolt size for fog light tabs?
Anyone know what the bolt size is for the fog light tabs?
cage, ht
rear light electiral hook ups paulb Defender Technical Discussions 25 January 19th, 2010 03:25 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Rollcage light tab thread size read Defender Technical Discussions 4 January 28th, 2005 02:33 PM
Fog light install SFD90 Defender Technical Discussions 15 January 13th, 2004 10:51 PM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
