rollbar lighting - Defender Source
Old October 15th, 2013, 10:34 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
rollbar lighting
For those with roll bar lights (Hella, etc), what is the path of the wiring from the lights to the power source?
Old October 16th, 2013, 07:19 PM
Most of the ones I have seen just use zip ties for the cables. Looks like ECR does as well.
I assume you could drill the bar and fish them internally but I think that it would take forever and open them up more to internal rust.
95' D90 - daily driver..
Old October 17th, 2013, 12:59 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I don't know if the original owner put the holes in mine or if they were from the factory, but I have a small hole near each mounting tab. I think the original owner may have drilled them and run the wires down to the cross bar by the windshield. When I redid it, I drilled a hole through the center of the foot and the lower mount so the wires run completely internally into the engine bay.
Old October 17th, 2013, 01:15 PM
JBOD77
Jonathan
1995 D90 ST Beluga Black
mine are ziptied up and across. i used a length of heat shrink tubing to contain everything
This is where I'm supposed to write something witty and funny; or something.
Old October 18th, 2013, 12:50 PM
CaptMidnite
Daniel Choi
Thanks for the responses so far. So after the wiring goes down the rollbar, does it just pass through the gap between the rear of the hood and bulkhead? There's sufficient clearance but it looks like an area with moving parts (hood going up and down) and a path for rain water drainage.
Old October 18th, 2013, 02:16 PM
JBOD77
Jonathan
exactly how mine is done.
ID:	82301   Click image for larger version
JBOD77
Jonathan
shit they're crooked.....sorry
Old October 18th, 2013, 02:18 PM
JBOD77
Jonathan
fixed
ID:	82303   Click image for larger version
Old October 18th, 2013, 11:26 PM
CaptMidnite
Daniel Choi
Ah ha, exactly what I was looking for, thanks!
ht
Instrument lighting shawnpalmer Defender Technical Discussions 1 October 17th, 2005 10:23 PM
intirior lighting Rover- Girl Defender Technical Discussions 1 October 14th, 2005 10:59 AM
WTB rollbar mpodgorski Wanted 0 March 17th, 2005 07:38 PM
ST rollbar pads mpodgorski For Sale - Parts 2 July 26th, 2004 10:34 PM
Nerf Rollbar Whatchamahatchies? OCD90 Wanted 0 April 9th, 2004 03:16 PM
