Roll up window measurements ... - Defender Source
Old July 18th, 2009, 11:29 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Need to replace both my front roll-up windows and am looking to get the correct measurements as I suspect the old ones were badly replicated.
Anyone ?
Thanks.
Pat
Kirk Lazarus, Tropic Thunder
Old July 19th, 2009, 12:08 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
do you know if they are the same as the glass from a set of 2008 doors?
If so I have mine apart right now and can take pics / measure if it will help
Old July 19th, 2009, 11:04 AM
Retrofit's Avatar
Retrofit
Pat
Yes I believe they are, I would be very appreciated.
Thanks !
Pat
Old July 25th, 2009, 08:09 AM
Retrofit's Avatar
Retrofit
Pat
Bump ...
Anyone ? Anyone ?
Pat
Old July 25th, 2009, 08:58 AM
pat
send me a reminder on monday and i will pull one out of the shed for you.
rgrds
d
Originally Posted by Retrofit
Anyone ? Anyone ?
Pat
Old July 25th, 2009, 09:17 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Sorry, I have been working a ton of over time at work and it slipped my mind
I will try to measure them today
Old July 28th, 2009, 06:21 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I suck but better late than never I guess
bottom 29" 1/2
back 21" 1/8
top 22"
front straight short part 6"
front part that slants back 17"
It is hard to measure due to the fact that all of the corners are ground down but I think they should be good.
Old July 28th, 2009, 09:50 PM
Retrofit's Avatar
Retrofit
Pat
Sweet !!!
Thanks Dave, don't worry all the shops here are closed for the construction holiday until next week so no worries there.
Pat
Old July 28th, 2009, 10:03 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
thats an odd holiday, you would think that the construction trade would take a holiday in the winter as summer is the busy time
Old July 29th, 2009, 10:28 AM
Retrofit's Avatar
Retrofit
Pat
I know ...
Man ! I believe its the most stupid holiday in the world. And we owe it all to the construction unions witch are plagued with organized crime here ( laundry anyone ? ). Its probably the best two weeks to get things done around here but some people just don't get it.
Ho well !
Pat
window
Need measurements for SW side window placement dave_lucas Defender Technical Discussions 17 May 30th, 2009 05:14 PM
Mounting Hella 4000 on Roll Cage Above Window jdvega Defender Technical Discussions 2 April 1st, 2006 04:34 AM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
