Roll cage torx bolt sizes - Defender Source
Old December 13th, 2014, 04:05 PM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
M removing the front roll bar piece under the windscreen to do some hinge work on the hood. What size torx bit do I need to remove those 4 bolts?
1997 D90 ST NAS #1426
British Racing Green
Old December 13th, 2014, 07:40 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
If you are trying to remove the hood, it comes off without removing the hinges. Take off the bracket that holds it open, then stand it straight up & pull straight up. It may take 2 people because it's awkward to do this by yourself.
Old December 13th, 2014, 08:36 PM
Nashville's Avatar
Nashville
Victor Hess
Pulling the hood to put the plastic roller spacers that insert into the "hinge" cylinders. Looks like it has to be almost straight up to fit into the slot on the spacer. I also want to know the torx size to replace rusty nuts on that rollbar section.
Old December 13th, 2014, 10:47 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
T-50
Bolt sizes for NAS ST rear tire carrier and bits? Rufus Defender Technical Discussions 3 September 5th, 2016 08:58 PM
Bolt Sizes sonoronos Defender Technical Discussions 6 November 25th, 2012 09:09 AM
Roll cage Torx bolt sizes mwmorgan22 Defender Technical Discussions 7 December 17th, 2008 08:31 AM
torx replacement for roll cage bennett Defender Technical Discussions 10 September 11th, 2008 11:59 PM
Gearbox Torx Bolt Billakris Defender Technical Discussions 2 January 2nd, 2007 05:50 PM
