Roll Cage Supports - Defender Source
Old September 7th, 2007, 12:09 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Roll Cage Supports
Need help with the installation of the roll cage support that runs perpindicular to and just above the frame right behind the seat box. The one I have is the two pieces (dog legs) and I can get one side in but I don't believe I can get the other side in and still make the male female connection. I hope its not true but I have a funny feeling that I have to remove the tub to do this???
Any help would be great,
Old September 10th, 2007, 12:51 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Thumbs up
Ok, I figured it out. You don't have to remove the tub for the two piece version which I believe to be a 97. You do however need to remove a sill/or rock slider to install them. Once the sill/slider is out of the way you have enough room to slide the two pieces together and then rotate up into place. It was a major relief this morning when I figured it.
cage
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
D90 Roll Cage Matting Cracks MDS Defender Technical Discussions 9 August 22nd, 2004 06:19 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
