Roll Cage Supports - Defender Source
Old January 21st, 2007, 12:11 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Roll Cage Supports
Need some measurements from a 97 90. First what is the diameter of the hole in the rear of the tub that the cantrail passes through. Second I need to know how far from the rear and the side of the body is that hole. I'm installing a complete cage in a non-NAS body and well don't have any of that info.
Old January 21st, 2007, 01:36 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
I may have used the cantrail term in error. I'm talking about the support that bolts to the cross member then runs up through the tub and bolts to the C pillar.
Old January 22nd, 2007, 05:41 PM
For a soft-top or station wagon? I could help you with a soft top.
Old January 22nd, 2007, 07:02 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Soft top.
Old January 22nd, 2007, 10:44 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Scott,
Here are some photos of what I'm talking about. The one shows the support that ties to the cross member and each end of said support. The other photo is that of the corner of the tub. It looks like the hole needs to be about 2 7/8 or so in diameter to allow the support to pass through it.
Name:	Rear Support 006.jpg
ID:	7973   Click image for larger version
Name:	Rear Support 007.jpg
Name:	Rear Support 008.jpg
ID:	7975   Click image for larger version
Name:	Rear Support 011.jpg
Old January 23rd, 2007, 08:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The soft top ones are 2 piece and they just sandwich the body. at least mine do..
Legend in My Own Mind.
Old January 23rd, 2007, 10:01 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Randy,
I believe yours to be a 94/95 type support. The 97's are the one piece type design.
Old January 23rd, 2007, 08:57 PM
Chris I will post a picture tomorrow... I got back late this afternoon.
Old January 24th, 2007, 11:56 AM
Shane@EVS
Roverhybrids
Chris,
The hole is approx 3", more like 2 15/16"
The far edge of the hole is 3.5" from the rear
and 4.25" from the side.
If you call it a 3" hole the center would be 2" from the rear and 2.75" from the side.
Both sides of the D90 are the same.
Old January 24th, 2007, 05:13 PM
Chris,
Here are some pictures... My speaker boxes did not want to come out without fight... Two of the pictures are of the connections on underneath the truck.
Hope this helps,
ID:	7994   Click image for larger version
ID:	7996   Click image for larger version
ID:	7998   Click image for larger version
Old January 24th, 2007, 09:29 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Shane & Scott,
Thanks for your efforts, this is exactly what I was looking for.
Old January 25th, 2007, 09:23 AM
Chris if you need more pics or specific pics let me know...
Old January 25th, 2007, 08:00 PM
Jase
Jase
pending
Curious what your plans are for the tail lights?
Old January 25th, 2007, 09:25 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Jason,
Who needs tail lights the truck barely goes 55. I'll always be the one following. But on a serious note the inside rubber housing will push to the side. Not idle but looks like it will work and I would assume the same for the lower amber light as well. If need be I will redo the lights since I would rather have the full roll cage. My current thoughts/plans call for the brake lights to relocate and I would utilize that location for a connection point for a roof rack similar to the factory/safety device mounting.
Old August 21st, 2007, 11:50 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Gentlemen,
On the attached photo what is the material that goes between the roll cage support and the tub? Picture is taken from underneath the truck looking up.
Old August 22nd, 2007, 07:26 AM
There is a rubber gasket/grommet that stretches to go around the top bracket, and then slides down the tube to fill the hole. I have no idea what the part number is, but McMaster may be able to supply something that works.
Old August 22nd, 2007, 08:02 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chris, my euro light setup fit when I installed the cage. You should have no problem. I think Mcmaster Carr has big grommits like that. IF not the part # is ALR7812.
Scott, I love the tons of mud behind the speakers... Is that MAR mud.. I keep finding that stuff everywhere.
Old August 22nd, 2007, 11:41 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Jim & Randy,
Thanks for the Mcmaster Carr link. I just will called a couple that I think will work.
cage
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
D90 Roll Cage Matting Cracks MDS Defender Technical Discussions 9 August 22nd, 2004 06:19 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
