Roll Cage Seals - Defender Source
Old December 4th, 2006, 10:08 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Roll Cage Seals
I should get my external roll cage back from powder coating pretty soon. While I cannot get myself to part with $8.72 per bolt (p/n ALR4444) from RN, I am questioning the seals for the external roll cage. I dont recall these seals being much more than a ring of closed cell foam of some sort when I removed them, very much unlike the rubber pads that I had on my 90. I have been told that the pads for the 90 willl not work on the 110. Can someone confirm what the roll cage seals on the 110 actually look like as I am not 100% that what I took off was original? Along these lines is there a better than factory option for keeping water out and hopefully doing a better job of protecting the surface of my tub from the rollcage?
Matt
Old December 4th, 2006, 10:23 PM
Matt, what did the powder coat run you (in case I want to go black in the near future?). I could use the benchmark.
Old December 4th, 2006, 10:56 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Local joint here quoted me $225 to strip/burn, blast and powder coat the entire cage & ladder. The only thing I did not have done was the roof basket. I went with a flat black, basically told them to match the ladder. The blasting was for all of the areas where I had some surface rust starting. Mostly at some of the welds and around the bolt holes. I will post some pics when I get the final product back.
cage, seals
Trade roll cage? bstraw Wanted 1 March 28th, 2006 05:44 AM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
