Roll Cage Rubber Seals Part Number(s)? - Defender Source
Old January 10th, 2008, 04:30 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I'm pulling the 110's cage for a repaint soon and want to order the rubber seals that go between the cage and the body panels. Does anybody have the correct part numbers?
I think that ALR5548 is for the front fender mount points, but don't know about the mid and rear mount points. Seems like the same part should work for all, but I've also found that ALR5558 and ALR3299 also refer to cage seals.
Thanks!
Chance
Old January 11th, 2008, 12:23 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I don't know the numbers off the top of my head and now I'm back in CO so I can't look them up, but I have all the new ones for my truck at home and they are definitely not all the same. Some are solid I believe and some are just an outline around the part that protrudes through. Also, there are different ones for the roof where it bolts through to the inner cage.
Old January 11th, 2008, 09:47 AM
surf110's Avatar
surf110
Ze
130 Project
Here you go:
ALR3298 Seal rear body outer x4
ALR3299 Seal rear body inner x4
ALR3300 Seal roof mounting x2
ALR3301 Seal floor mounting x2
ALR5548 Seal front fender outer x2
The only ones I don't have listed are: Seal front fender outer x2. Might be the same are rear.
Old January 11th, 2008, 01:55 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Chance,
I got a complete set from George last summer with no issues, pretty inexpensive as I recall.
Matt
Old January 11th, 2008, 04:33 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Excellent, thanks! You guys are the best.
Chance
cage, part, rubber, seals
Roll Cage Seals mattarm Defender Technical Discussions 2 December 4th, 2006 10:56 PM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
D90 Roll Cage Matting Cracks MDS Defender Technical Discussions 9 August 22nd, 2004 06:19 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
