Roll Cage Repair Options - Defender Source
Old August 16th, 2011, 01:31 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
So I took a couple of 1/2 grapefruit size chunks out of my roll cage this weekend.
One of them I have most of the chunk...they other I have nothing.
I found a few options online ofr patching/filling...wondering what experiences people have with these:
Flexane:
http://www.devcon.com/products/produ...E%2080%20Putty
Padded Dash Filler:
http://www.urethanesupply.com/catalo...ed+Dash+Filler
Evercoat Selant Foam:
http://www.evercoat.com/productDetail.aspx?pID=308
Not so interested in aesthetics as I am with keeping water out from behind the foam...
Aslo, does anyone know the "hardness" of the rubber that I could use to match the Flexane?
Dave
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old August 16th, 2011, 03:12 PM
specops1526's Avatar
specops1526
Beluga '97 90
Not sure about huge repairs like that but I posted about how I fixed some tiny damage on my cage here:
http://www.defendersource.com/forum/...ollcage+repair
you may need to make some molds to use this stuff but that should be easy.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 16th, 2011, 03:19 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
You can get the polyurathane in expandable foam. Most home and hardware stores have it. It's black and comes in the small cans.
Old August 16th, 2011, 03:48 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
So like:
http://www.hitecindustries.com/polyfoam.php
or
http://greatstuff.dow.com/products/pond-and-stone/
Looking for something that is more dense/less brittle than the yellowish expanding foam I have seen before...
------ Follow up post added August 16th, 2011 02:54 PM ------
Or going more advanced:
http://www.polytek.com/cart/index.ph...ategory_id=274
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old August 16th, 2011, 04:47 PM
kevkon's Avatar
kevkon
kevin
I have used the GreatStuff and it's pretty hard. I'm not sure how you would apply it for your cage. perhaps find some material with a similar texture that is stiff, wrap around the area you want to repair and clamp it with some hose clamps. Provide a fill/bleed hole and fill it. Might work.
Old August 16th, 2011, 06:23 PM
Tony Lawson here-16kpsi was going to start redoing these. Not sure he made any headway before diving into a Cummins 6b conversion for his 110 but worth pinging him.
Old August 16th, 2011, 06:31 PM
killahaas's Avatar
killahaas
Dylan Haas
none for now!
why not just cut out the section sleeve it and weld in the section?
Old August 16th, 2011, 06:32 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
killahaas - damage is only to the foam.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 20th, 2012, 01:21 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
OK...so I finally did it.
Had two holes in the foam: One on the rear vertical and one on the rear horizontal. I had the foam piece for the vertical but not the horizontal.
I used DAP rooftop and blacktop sealant to "glue" the one chunk into place.
I used gray expanding foam to fill in the gap on the horizontal and then used the DAP as an overcoat to color/texture map.
Didn't turn out too bad...but I may go back and do some more work on it later.
The hole in the horizontal bar was 6 in long and 1/2 around.
Found a pic of the damage as reference.
I think if I did it a second time and spent more than 15mins, I would get it near stock...
ID:	50582   Click image for larger version
ID:	50584   Click image for larger version
Name:	Cage Damage.jpg
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 20th, 2012, 02:29 PM
Are you going to fill in that entire missing section?
Old April 20th, 2012, 02:31 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
I did. See the 4th pic.
Used expanding foam, carved it down and then covered with the sealant.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 20th, 2012, 02:34 PM
Well done...
Old April 20th, 2012, 02:36 PM
If you're able to get a pic of the horizontal in better light, post it up. Wow! I was thinking you filled in little pin holes - that thing was huge!
Old April 20th, 2012, 02:47 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
nice work!
Old April 20th, 2012, 02:58 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Here is a pic in better light ... Not perfect but worth the 15 mins...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 20th, 2012, 06:45 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
That looks pretty good for the size chunk you fixed. What did you use to place and texturize the sealer?
Old April 20th, 2012, 07:36 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Shot the sealant onto the foam and spread it out with my hand..but it was really tacky and ended up looking like stalagmites. I waited an hour and "sculpted" with my hand when it was dryer. Followed up a day later with emery paper.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 24th, 2012, 09:05 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Dave - That looks great. I have very similar breaks in the padding on my cage and will definitely give this a try. What did you use to hold the foam in place on the bar?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old April 24th, 2012, 11:20 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
The foam is a sticky expanding foam...I sprayed it in and then once it expanded and dried, shaped it with a sharp knife.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old August 4th, 2015, 12:23 AM
jperakis
James Perakis
94 ST
Resurrecting this old thread.
Chunk missing from my left side H bar and I'm going to fill it using this technique over the weekend.
I'll be sure to post pictures.
remember two things...
cage
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
Roll cage options mod4b Misc. Chit-Chat 2 March 23rd, 2005 01:17 PM
roll cage repair willtillery Defender Technical Discussions 0 October 4th, 2004 09:15 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
