Roll Cage Repair Options - Page 2 - Defender Source
Old August 4th, 2015, 04:32 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Let me know how it turns out. 4 years later and mine still looks good.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old August 5th, 2015, 09:39 PM
toona's Avatar
toona
Toona
1994 D90
Subscribed.. I will do the same after you
Old August 10th, 2015, 12:24 PM
jperakis
James Perakis
94 ST
I followed the general guidelines of this method of repair and I'm pretty damn happy with the results.
The biggest issue I ran into was color matching the original rubber padding to the new sealant coat. When you use a sealant it comes out slimy and shiny - not at all like you want the final product to look - but give it the time to set and it dries to a nice matte finish.
My roll cage (H bar) not only had a chunk missing but had a couple of cracks on the ends.
I used some heavy duty glue (allegedly waterproof) for my work on the cracks. They look fantastic now.
To repair the chunk here's steps I took:
1. Clean the missing section
2. Use a foam filler and fill in the gap of the mission section (I used Great Stuff and it expands fairly aggressively but it very easy to mold and cut once it has the opportunity to dry).
3. Cut away excess foam
4. Sand down foam to meet the contour of the roll cage
5. Apply sealant ( I used Henry Rubberized Roofing Sealant)
For step 5 I just threw on a pair of plastic gloves and worked it all over the place using my fingers and a small knife to help shape. As noted this stuff is very sticky and shiny when it comes out of the tube, be prepared with supplied like paper towels when using this stuff!
All in all, fixing the cracks and filling the gap were both easy tasks.
The "toughest" part is being happy with the final product after you apply the sealant. I applied 3 coats over 2.5 days to fill in various spots.
ID:	126886   Click image for larger version
ID:	126888   Click image for larger version
remember two things...
Old August 10th, 2015, 12:30 PM
jperakis
James Perakis
94 ST
Additional Pictures
ID:	126892   Click image for larger version
ID:	126894   Click image for larger version
Old August 10th, 2015, 12:34 PM
jperakis
James Perakis
94 ST
i'll post an update once everything is completely dry and the cage is back up on my truck.
Final side note - NAS D-90's look badass without the safari cage!
Old August 13th, 2015, 09:02 PM
jperakis
James Perakis
94 ST
Here's a side by side of the before and after.
Not perfect but I'm definitely happy with the result.
ID:	127100   Click image for larger version
Old August 13th, 2015, 10:44 PM
Pretty darn good!
Old August 14th, 2015, 06:17 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Nice work. What was the glue used?
Old August 16th, 2015, 02:38 PM
Agreed, well done!
Originally Posted by pendy
I'm here for the D's
Old May 15th, 2017, 08:58 PM
Grover's Avatar
Grover
Looks great! What brand/type of glue did you use?
cage
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
Roll cage options mod4b Misc. Chit-Chat 2 March 23rd, 2005 01:17 PM
roll cage repair willtillery Defender Technical Discussions 0 October 4th, 2004 09:15 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
