Roll Cage Help - Defender Source
Old June 3rd, 2016, 02:01 PM
mmgcny
Michael
Roll Cage Help
Does anyone have experience with Safety Devices roll cages?
I am looking to potentially convert a 90 SW to soft top. I am looking to fit a NAS like cage, and to also remove the rear bulkhead and fit a bulkhead removal bar.
Is there a cage similar to RBL188 7SSS that will work with a truck with no bulkhead? Has anyone used this cage and modified it to work on a truck with no bulkhead?
SD RBL2367SSS is the rear portion of the cage that looks like it will work without a bulkhead. Is there a particular bulkhead removal bar that works with this?
Could RBL138 3SSS be modified to integrate with RBL2367SSS?
Additionally, does anyone know any fabricators to could make a NAS cage copy?
Old June 3rd, 2016, 02:30 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I believe Brian AKA Brewie AKA LRC Customs has done some cages that give an apperance of the NAS cage.
Land Rover Customization Shop - Raleigh NC | LRC Customs
Old June 3rd, 2016, 02:38 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
LA's urban off-road had made some in the past, but without real demand, he stopped. Might again if there was enough interest. At least that's what he told me. I'd rely on Brian (Brewie212).
ID:	150888   Click image for larger version
Old June 5th, 2016, 09:40 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
FWIW the green truck linked on RBL188 7SSS has the bulkhead removed. I would call up SD and ask them to weld in points for a bulkhead removal bar. Alternatively just using a BritPart bulkhead bar might do the trick.
cage
Need help getting roll cage OFF vehicle ;) nickybee Defender Technical Discussions 6 October 5th, 2015 05:27 PM
NAS Roll A bar roll cage and front under wing supports defenderholty For Sale - Parts 6 August 9th, 2014 05:49 PM
Implications of going from a NAS roll cage to Full Body Cage. Manimal Defender Technical Discussions 19 June 25th, 2013 08:26 PM
Roll Cage help bjf Defender Technical Discussions 21 March 11th, 2008 05:00 PM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
