Roll Cage help - Page 2 - Defender Source
Old March 7th, 2008, 07:07 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
RN used an early UK spec tub on that pick-up conversion. I have some tubs with the rear bulkhead and I'm not sure, looking at them, how you would get any Rover "b pillar" parts to work. It would need to be fabbed.
The roll cage from the ECR truck is in an HCPU which is somewhat different. Also wasn't actually mounted to the frame, just sitting in the tub and on the fenderwells. I would suggest frame mounting if it is intended for anything other than looks.
Off topic; As for the white truck with the dual tanks. I don't know who installed it but the saddle tank is a standard UK / Euro spec using the corresponding filler, in addition to the NAS spec tank and filler. Uses a transfer pump.
Side note; The late Euro spec tubs are available with a rear fill and the rear bulkhead for those that would desire a PU with a "NAS correct" rear fill.
Matt Browne
Old March 11th, 2008, 05:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
Here is a pic of where the seat belt attaches right now
http://www.flickr.com/photos/barryrides/2326842615/
cage
snaps missing in roll cage jaherring Defender Technical Discussions 4 March 17th, 2008 11:23 AM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
