roll cage Defender 90 - Defender Source
Old June 7th, 2016, 09:27 AM
spyder625
110
can the padding be replaced on the roll cage or somehow removed and put new padding on it? thanks for your help.
Old June 7th, 2016, 09:44 AM
bjf's Avatar
bjf
barry f
94 ST #395
I assume you mean on a soft top cage. You can't remove it. There are ways to fix cracks, but if overall you have dry rot you are screwed. Rovers north has a set of pads that cover the entire thing so it will look better.
Post pics of the cage if you want the best advice.
Old June 7th, 2016, 09:51 AM
spyder625
110
Padding Picture
here is a shot, it's torn on the bottom. I actually ordered from rovers north the padding but thought I could remove all of the old first for a neater install.
Old June 7th, 2016, 10:07 AM
bjf's Avatar
bjf
barry f
94 ST #395
Be happy that is a minor repair in the grand scheme of things. If you do a search you will find info on what people use to make repairs. There is a roof flashing product you can use to fill that hole. Just need to do it slowly and build it up. A sponge works for texturing the final coat.
Old June 7th, 2016, 10:37 AM
That's not bad at all. New truck to you?
Old June 8th, 2016, 02:37 PM
spyder625
110
yes, just picked it up. Trying to locate a great body shop to do some paint work in Northern NJ?
Old June 8th, 2016, 03:34 PM
jperakis
James Perakis
94 ST
I did exactly that to fix a much larger gap in my cage (on the cantrail)
I don't think the RN kit covers the feet where you are experiencing cracking.
A nice glue and some gentle pressure will help.
remember two things...
90, cage, defender, defender 90
NAS Roll A bar roll cage and front under wing supports defenderholty For Sale - Parts 6 August 9th, 2014 05:49 PM
Implications of going from a NAS roll cage to Full Body Cage. Manimal Defender Technical Discussions 19 June 25th, 2013 08:26 PM
NAS Defender 90 Roll Cage FORSALE RoverWrecks For Sale - Parts 2 April 8th, 2009 11:11 PM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
Roll Cage Wanted for my 95 Defender 90 edducati Wanted 6 July 28th, 2004 03:34 AM
