Rockware bumper on a '97 D90? - Defender Source
Old August 14th, 2006, 02:08 PM
Guys, can you confirm a rockware bumper (with winch) can be installed on a '97 D90 without relocating the transmission cooler?
My '94 has an auto box and I'd like to use a '97 transmission cooler which mounts in front of the transmission (not on the engine side like mine). It fits behind the lower aluminum section below the plastic grill I am told, but have not seen one. Rockware says their bumper fits without mods, but I want to make sure.
If anyone has pictures of one, even if not specifically showing the location of the transmission cooler on a '97, please let me know.
Which winch I will buy is TBD if that matters.
thanks
charles
Old August 14th, 2006, 02:11 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
It definitely fits without mods.
Old August 14th, 2006, 02:17 PM
Thanks!
Do you have any pictures showing the transmission cooler on your truck? Can you think of any reason I'd have trouble mounting one on my '94?
thanks
charles
Old August 14th, 2006, 03:16 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
No specific pictures. It's mounted in the stock location.
Old August 14th, 2006, 05:56 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
I concur with Dave. Should have no issues mounting a RW bumper. I can send pictures later tonight, if you need them. Mark
Old August 14th, 2006, 06:46 PM
I'd love some pictures! If you can show the transmission cooler mountings, or how the front aluminum is vented, that would be fantastic.
thanks
charles
Old August 14th, 2006, 08:11 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
thanks
charles
Charles, it vents in the same way as before. Does your radiator fascia have the holes at the bottom like the A/C versions (mostly '97's)? Or is it a solid panel at the bottom?
Old August 14th, 2006, 09:01 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Charles - Here are some images I had on hand. Will try and get some images of the mountings. Mark
Name:	RW Bumper composite.jpg
Old August 14th, 2006, 11:02 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
thanks
charles
Charles-
I converted my 94 to an auto and used the stock 97 cooler which mounts basically under the radiator. I have a Rockware bumper/winch combo, you will not have any issues mounting those. What you will have to do is cut out the aluminum ovals below the grill since you don't have any vents. If you are going for a total factory look you could probably source the lower facia from a 97, but it is simple work you can do with a dremel tool. I had a picture that I sent to someone else, I'll see if I can find it or try to take another one.
Tis
Old August 15th, 2006, 07:49 AM
artm
Arthur Maravelis
97 SW
I don't think there is a lower front facia - it is one unit to the top. To go on the cheap, take it out, cut out one big rectangle (round the corners) and attach a screen behind it. That will give you maximum airflow.
Old August 15th, 2006, 09:07 AM
Thanks guys, this really helps.
Yes my facia ia solid, and I think Art's suggestion is best - to just cut a rectangle and screen it. If you do have a picture handy Johnathan, I would like to see how you did yours.
I'm probably pushing my luck here, but does anyone know what size fittings the stock cooler has? I'd like to get my lines rebuilt while I wait for it.
Thanks to all.
charles
Old August 15th, 2006, 09:56 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
here you go.
ID:	6240   Click image for larger version
Old August 15th, 2006, 10:35 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Charles, there are a bunch of pics of my 97 w/ rockware bumper in a recent thread talking about "255x85 tires" somewhere here. My truck is up on a ramp so you should be able to see things from a different angle. If you cant find it and need to see i can send the pics via email.
Clay
Old August 15th, 2006, 12:26 PM
Thanks a lot Johnathan.
Clay, saw the pics, thanks. Didn't see much of the cooler except the way the lines ran underneath (which helps), but what caught my eye was the way the bumper mounter to the frame. My ends have been cut off, so I'll need to make sure thats not an issue for me. Maybe you can make one of the nova happy hours (there is one on the 29th) and I can take a good look up close?
thanks again
charles
Old August 15th, 2006, 12:31 PM
1of40's Avatar
1of40
1of40
I'll try to make it. You're always welcome to stop by the house to take a look too. I'm about 20-30 mins away form south riding in the cascades development; if you're familiar.
Old August 15th, 2006, 04:06 PM
Clay, I think thats probably the best plan. I might run out of things I can do on my truck while waiting for parts the next day or two and will have the time to swing by - what hours will you/your D be there?
charles
Old August 15th, 2006, 04:16 PM
1of40's Avatar
1of40
1of40
I'm usually home little after 7PM most nights. I'm around during the mornings this weekend and out of town next week.
Cell: 202-412-9107
Old September 6th, 2006, 01:41 PM
This is what I ended up doing. I took it to a local shop as I didn't think I could do the cut clean enough. They rounded the bottom of the cut, not the top (not sure how that got lost in the request) but looks fine this way.
charles
Old September 16th, 2006, 08:22 PM
about the rockwares it seems like the light mount really sticks out a ways has anyone ever worried about tearing a light off? Do they come with two or three holes for lights? Or is it all up to the buyer
Old September 16th, 2006, 10:48 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Its up to the buyer. You can also have them change the amount that the A bar sticks out. Ken had them push the angle back so it sits straighter.
Jimmy Buffett
90, 97, 97 d90, bumper, d90, rockware bumper
Rockware bumper for D90 Shane@EVS For Sale - Parts 16 April 5th, 2006 01:16 AM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 17 October 14th, 2004 11:32 AM
Wanted: Stock Front Bumper for '97 D90 david_jackson Wanted 4 September 28th, 2004 08:06 PM
D90 ARB front bumper w/ winch mount taoseno For Sale - Parts 0 August 10th, 2004 01:41 PM
Rockware front winch bumper dave_lucas For Sale - Parts 6 April 3rd, 2004 10:48 PM
