Road Speed Sensor - Defender Source
Old February 16th, 2010, 03:31 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Road Speed Sensor
Check engine light went on a few days ago. Checked the code 68 which came up as road speed sensor. Searched here and found what the code meant and what ppl did to correct it. But... where do I find the sensor to see if it need to have the connector cleaned or replace the whole sensor?
Anything else I should be looking for?????
Clarence
Old February 16th, 2010, 04:24 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
It's underneath the truck, on top of the transmission crossmember, drivers side. Just follow the speedometer cable down, it's easy to feel it but difficult to see with your eyes.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 16th, 2010, 09:37 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Thanks! I will look for it. I will also be disconnecting the battery to see if the error comes back.
sensor
Rough Road Sensor?? scubadanster Defender Technical Discussions 25 April 19th, 2007 02:00 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Road Trip Report, Defender Sightings chris snell Misc. Chit-Chat 5 December 28th, 2005 03:03 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 09:44 PM
