RN Heavy Duty Steering Rod Set vs Terrafirma vs Original Tie Rods - Defender Source
Old November 7th, 2017, 08:03 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
My tie rod ends are toast. Thinking about replacing w RN Heavy Duty Steering Rod Set. A set of original tie rod ends are around $180 and the RN set is around $200...about same as terrafirma set. Can anyone attest to the quality/performance of either of these sets vs the original?
Old November 7th, 2017, 08:15 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
TF and our RN shafts are pretty identical, both are much more stout than the original.
Old November 7th, 2017, 08:57 AM
The Dro
Dro
1988 Ninety
I have the RN ones and they are identical to the TF
Old November 7th, 2017, 09:05 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I recently put the RN HD steering set on my 90. Pretty pleased with it.
I don't know what make the TRE's are but they are suitable for my daily driver/non-crawler application.
They have the grease zerc, too.
Use plenty of silver antiseize grease when installing and get your jam nuts TIGHT after you align everything.
Rent my
Old November 7th, 2017, 12:16 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
Yes, RN's are great. For the $20 difference you should absolutely go for the RN set vs original. Many "original" or aftermarket-non-hd ends don't have grease fittings and to price out a set from your local parts store or summit racing etc will set you back the same coin plus your time running around. They add +10 overland points too.
Call Zack and just send it
Old November 7th, 2017, 12:33 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
I went for the TerraFirma. Only $87 + shipping.
Old January 17th, 2018, 07:33 PM
redline_r
Ridwan
1986/Land Rover 110
I understand there was a Keith at Rovertracks that was making a good set--is that anywhere under a different name?
The TF hd tie rods I've found is MUCH more than $87... Am I looking at the wrong one?
Lastly, should I get new tie rod ends at the same time? If so, recommendations?
Ridwan
Sent from my Nexus 6P using Tapatalk
Old January 17th, 2018, 07:52 PM
AdamSanta85
91' D90 200TDI
Price went up slightly due to exchange rate but close enough at $93
https://www.lrdirect.com/TF250-Heavy...keep_https=yes
Old January 17th, 2018, 08:10 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Keith retired from Rover parts.
Rent my
Old January 17th, 2018, 08:30 PM
Noyac40's Avatar
Noyac40
1985 D110
Thats is the one that I just rec'd, looks like a great kit for the $91 I paid.
Old January 17th, 2018, 08:38 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
$73 for TF250 at Ribble Valley if anyone else is looking.
TF250 - HEAVY DUTY STEERING ROD - Land Rover Parts
Good prices on galvy Richards Chassis and some other stuff too.
KGH - “Stinky LR diesel” Defender Snob
Old January 18th, 2018, 12:54 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I really like switching to the Disco style pitman arm while doing this. It eliminates that press in ball joint that is such a pain in the ass.
Old January 18th, 2018, 07:56 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I’ve had Rovertym’s front and back rods on my truck for prob 12 years now. Prob no difference from the RNs. Not much science to them.
Old January 18th, 2018, 10:26 AM
wantone
Rick Thompson
94 ST #1222
how does the finish hold up on the TF's & RN's?
Old January 18th, 2018, 10:56 AM
More serious options. https://gwynlewis4x4.co.uk/sumobars/
Old January 18th, 2018, 12:22 PM
redline_r
Ridwan
1986/Land Rover 110
Originally Posted by Red90 View Post
I saw those sumobars, but was suspicious since they never came up on one of these threads before, haha!
Thanks for the links, folks.
Red90-- can you explain a but more about the discover style arms? (Beginner explanation, please!)
Old January 18th, 2018, 12:36 PM
The Discoveries used normal tie rod ends at the steering box (pitman arm). Defenders used a tie rod end that is built into the Pitman arm. You can change to a Discovery pitman arm and then use the Discovery tie rods. This makes future servicing easier.
All the Gwynn Lewis stuff is top notch.
original
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
110 Middle Row FLOORMAT - Heavy Duty? STC50173 pcscharfe Misc. Chit-Chat 14 May 29th, 2009 05:02 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Wanted ARB locker, Heavy duty CVs BradforD90 Wanted 1 October 1st, 2004 08:32 PM
Bearmach Springs Heavy Duty... h2eater For Sale - Parts 0 July 9th, 2004 12:40 PM
