Rivet-nut questions - Defender Source
Old June 14th, 2010, 11:31 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Rivet-nut questions
I ordered the rivet-nut gun from Northern tool, now I need to order rivet-nuts for my build.
Not exactly sure what size, type or material to order for the following areas.
NAS Frame
I am trying to find the size or part number of the rivet-nuts ( 3 per side ) that attach the under tub support bar to the frame.
Bulkhead (part number nn108021)
I believe they are 8mm and I assume steel. I am thinking the following ones would work but please correct me if I am wrong.
95105A191
http://www.mcmaster.com/#rivets/=7j2cx8
Licenses plate (part number NN106021)
I would think they would be aluminum but not sure
M6 Aluminum,
94020A383
http://www.mcmaster.com/#94020a383/=7j2ge3
Are there any other styles or sizes that I should order?
Old June 14th, 2010, 01:19 PM
The license plate ones are steel from the factory. They suck, err, rather, they suck when you use something other than plastic screws. Given how few there are on the truck, I just ordered genuine ones from RN all were in stock and only the big ones on the bulkhead were more than a dollar or so.
Old June 15th, 2010, 01:10 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Seems like aluminum on aluminum would be better than going with aluminum on steel for the lic plate? Am I missing something?
Do you happen to have the part number of the ones that attach the under tub support to the frame or a size?
Old June 15th, 2010, 09:10 AM
I use aluminum in aluminum, and steel in steel. I purchase all my rivnuts through an ebay seller called HomePro.
My favorite things to have rivnutted:
1) Beverage holder on my tuffybox console. (so much easier to remove the tunnel cover now)
2) Parking Brake handle mounting bolts.
3) Jump Seat floor bolts.
I love rivnuts.
Old June 15th, 2010, 09:21 AM
I use 1/4 20 aluminum rivet nuts to install plates on the ROW trucks. I have been buying the cheap assortment box from Harbor Freight
Old June 15th, 2010, 09:29 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The tool I purchased from northren is metric so I will have to go with metric but it looks like Aluminum wins for the plate.
Anyone happen to know the size or part number of the ones that go in the frame to hold the under tub support bar
Old June 15th, 2010, 09:38 AM
Cant you just buy different mandrels ? My tool has both metric and sae sizes.
Old June 15th, 2010, 09:47 AM
I picked up mine from Harbor Freight it was about $15.00 and came with rivnuts and multiple tips/sizes. The replacement rivnuts are $10 each specific size pack you want.
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
Questions for a magazine chrisvonc Misc. Chit-Chat 11 December 3rd, 2003 02:42 PM
