rive nuts - Defender Source
Old March 17th, 2004, 12:06 AM
mattdh's Avatar
mattdh
Matt Hurst
rive nuts
i thought i saw a post about installing these with out a gun.something with a bolt maybe?any one know how to do it with the bolt?
Old March 17th, 2004, 12:24 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
yeah you can put a bolt through the thing (that fits it) and turn it so that it is all the way on and then keep turning at which point the thing will start to set.
Old March 17th, 2004, 07:55 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
I had a real tough time trying to figure out these things when I installed a hard top to my '94 a couple of years ago. I bought the retro-fit kit from LR. I drilled the holes as specified, but the rivnuts slipped right into the holes and spun with no resistance??? I ended up using JB Weld on them, did the trick, but I am still clueless as to how to use rivnuts?
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old March 17th, 2004, 11:21 AM
ronward's Avatar
ronward
Redsrover
None - sadly
You have to drill the hole for the rivnut slightly smaller than the actual rivnut. In reality, manufacturers make the rivnuts larger than the diameter hole they are spec'd for.
Put electrical tape, jb weld or something on the outer surface of the rivnut and hit the bolt with an impact wrench. Will seat right in nicely.
When I installed a set of RTE sliders on my Disco I used a pneumatic pump rivnut setter, but used the rattle gun method when adding some bracing to my SIII 109 ex-military last year.
Quick-release nuts for door tops - can anyone remember these? chittybangbang Defender Technical Discussions 20 May 30th, 2005 10:57 PM
hub nuts jimmy salmon Defender Technical Discussions 2 March 13th, 2005 06:00 PM
Disco II Lug Nuts javelinadave For Sale - Parts 0 January 21st, 2005 11:55 PM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
Lug Nuts!!! Get loose today !!!! Vadim Defender Technical Discussions 10 October 26th, 2004 03:58 AM
