Right front wheel whine - Defender Source
Old January 26th, 2006, 10:14 AM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
when accelerating or decelerating I get a whine from the location of the right front wheel. It is only noticeable when the speed is above 45. I have changed all the hub fluids and such (the sound was there before), and it is still there so I thought I would ask what people think? It is a manual 95 SW.
Bill
Old January 26th, 2006, 10:25 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
Is it definately the front wheel or is it the front differential thats whining. If its the wheel then possibly a wheel bearing
Old January 26th, 2006, 10:52 AM
kolvedic's Avatar
kolvedic
Bill Lewis
I am pretty sure it is the wheel. I would think the if it was the diff, I would hear it more towards the center? Anyways, I will get my redneck buddy to hang off the front and listen for the sound.
Oh, if it is the wheel hub, how easy is it to inspect/repair it?
Bill
Bill
Old January 26th, 2006, 10:53 AM
When was the last time you replaced or repacked the front wheel bearings?
Old January 26th, 2006, 10:57 AM
kolvedic's Avatar
kolvedic
Bill Lewis
I just bought it 6 months ago, so I am not sure when it was last done. Probably needs done as just about everything else did too.
thanks,
Bill
Bill
Old January 26th, 2006, 11:30 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I'd pull that bearing right away, cheap and easy. If you wait it could be expensive and difficult. Any manual, haynes etc, shows you how to do it. Cheap even to have someone else do it.
Old January 26th, 2006, 12:33 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Yep, it is easy, but you do need to get the hub wrench to do it. Also, mine has some short lengths of hard brake line running to the caliper. If you are extremely careful you don't have to disconnect the brake line to get the caliper out of the way, but if you have one of those things to make bleeding brakes easy, I wouldn't risk busting that line..... just remove it.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 26th, 2006, 02:01 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Great! I ordered the parts and they are on the way. I found some great articles online and I have the repair guides. As for the hub wrench, I assume you mean the 52mm wrench or socket?
bill
Bill
Old January 26th, 2006, 03:19 PM
Hans's Avatar
Hans
Hans Haase
Yep, that's the one.
I've actually found the front knuckle area on my Defender to be MUCH easier to work on than the typical american 4x4 style with the pressed on brake rotors, locking hubs, and open knuckles.
-Hans
My oil line fix
Old January 26th, 2006, 04:02 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
The only other thing it could be if the bearings look good is the CV joint.. but that makes more of a clicking sound. IF the bearings look good, dont put it back together just yet... I would then pull the spindle off. Only 6 bolts and check the cv for damage.
Legend in My Own Mind.
Old February 23rd, 2006, 09:23 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Just wondering if you got rid of that wheel whine?
I think I heard mine doing the same thing, intermittently...
Does it sound like a tea kettle boiling?
I just put a locker in the front, but I didn't take off the hubs to do it...
The wheels have no play (like one would if the bearing was bad).
I think I'm going to do it anyway.
Forgot this...
Maybe it could be the fluid in the ball joint?
I have never changed it...
But I saw the fill hole plug when I did the front locker.
Old February 23rd, 2006, 09:54 AM
kolvedic's Avatar
kolvedic
Bill Lewis
Actually, after pulling the hub member and inspecting all the bits inside, everything looked really good. So, I actually took mine to a local shop and had them look at it and turns out its not in the hub but the main gearbox. On a test drive, he popped the transfer case into neutral and the sound went away.(?)
Since I am the only one in the truck 99% of the time I am going over 50mph, it just sounds like it is coming from my right side I guess. They visually inspected everything and changed the fluids for me. There is normal wear and tear and my truck is nearing the 100k mark. The whine is still there but it is less.
I hear it as more of a metal whine, not as loud as a kettle but still there. Kind of like drilling metal almost, I guess.
Funny, I have owned the truck for 6 months now, and the last fluid I had to change was the tranny so I guess murphy strikes again. I even had the MTL in the truck... I would definitely drain and fill the swivel pin housings if you haven't done that.
Bill
Old February 23rd, 2006, 10:03 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
I'm on that today!!!
Yeah, my noise doesn't stop when I pop it into neutral.
It stops when I stop motion.
Then picks up again sometimes at certain speeds.
And my noise sounds like it is coming from the front left too.
Heath
Old February 23rd, 2006, 10:06 AM
Question William, the noise goes away when you put the tcase in neutral, how about when you push in the clutch?
Heath does it happen when you turn the wheels one way or the other? Speed make a differance or what gear you are in?
Old February 23rd, 2006, 10:11 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Speed yes. Gear, clutch, transfer -- no.
It happens on straight road or turning, maybe severe bumps (1-9) into Hoboken, can make it start or subside.
I thought is was a brake wear indicator on the front, but it wasn't.
Do I put 80w-90 in the swivel housing?
I hope it's just fluid/oil...
That would be a first!
Heath
Old February 23rd, 2006, 10:20 AM
Hmm, might want to make sure everything around there is good and tight, all the suspension componants and the steering stuff. You might also want to take a look at the engine mounts.
Old February 24th, 2006, 01:12 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Mike,
Duh, I didn't even think of that. Sure enough, if I am at speed and put the clutch in the whine stops.
Bill
Bill
Old February 24th, 2006, 01:30 PM
Hmmm Well then the sound is not nessicerily from the main gear box but it really still could be anything drive line related as it only makes noise when under load, when the mechanic pt the t-case in neutral all he did was unload everything, same as pushing in the clutch..
Really the best thing to try is driving with one drive shaft at a time to try and isolate the problem to either the front or rear axle, or the tranns / tcase. Once you have a direction to look in you can try and diagnose the problem.
Old February 24th, 2006, 04:20 PM
kolvedic's Avatar
kolvedic
Bill Lewis
I suppose to run 1 driveline I need to drop the other? I replaced the front driveline's u-joints last week, but the sound persisted. The U's were pretty dirty and I think were the originals. I guess when I replace the rear I could drive it with the driveline off and see if it still makes the noise.
thanks a bunch,
Bill
Bill
Old April 26th, 2006, 12:02 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Did you ever find out what this is? I have a similar issue.
ht, wheel
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
