Right front wheel whine - Page 2 - Defender Source
Old April 26th, 2006, 12:07 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
No. I did dynamat the entire inside and turn my radio up though
bill
Bill
Old April 27th, 2006, 04:13 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
One thing I've noticed is that, with the parking brake set, when I take my foot off the brake pedal on an incline, the truck moves a little bit. This should indicate an issue with the rear u-joints, doesn't it? I drove with the radio off, and I also hear the characteristic "clunk" when I let off and press on the accelerator.
Old April 27th, 2006, 07:58 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Bad ujoints that I have had always make more of a ping noise than a clunk. With an automatic set the handbrake and shift into drive and then reverse and listen for the ping.
Or is it more of a clink?
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old April 28th, 2006, 12:59 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
[QUOTE= With an automatic set the handbrake and shift into drive and then reverse and listen for the ping.?[/QUOTE]That doesn't sound right for a D-90, since the handbrake drum is on the transfer case rear output shaft, not the rear wheels like it is on most trucks.
I travelling this weekend; when I get back I'll crawl underneath and have a look-see.
Old April 28th, 2006, 05:51 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I'll bet you're right, just put your foot on the brake and do the same thing.
Old June 21st, 2011, 11:08 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I am getting a whine, from I think the front end, that increases with speed when I get above 35MPH. The whine goes away when I let off the gas. I have an auto in the 90. So it seems like something driveline like u joints or cvs..?
It also seems hard to get up to speeds above 70. Of course I am new to the D's so maybe I'm not used to running the gas soo hard lol. But it kicks down constantly when get going that fast and hills dominate it. More than 55 mph up the passes is asking alot of rpms. I did a compression check with the tune-up and they were all 150-135 so pretty close. According to harbor freight quality...
I also have an intermittent softer than normal brake pedal. Sometime they are real tight and stops on a dime, sometimes you need to make sure you're watching you don't rear end someone. So that brings bearings to mind, but my whine isn't constant.
Any ideas?
Thanks guys!
Pete
Old June 22nd, 2011, 07:32 AM
Transfer case whine or does it sound different? Your loss of power may just be the normal sluggishness of the Defender, as I believe we all suffer a bit uphill.
Old June 22nd, 2011, 07:55 AM
Broncoduecer
peter
D90
Maybe the the transfer case. Too bad there aren't more 90 owners around here and we could compare sounds. From reading other posts it sounds typical, but the results are varied. I think u joints a in order any since i have no idea how old they are.
Old June 22nd, 2011, 08:30 AM
Check your wheel bearings are not loose. Your statement about the brakes makes it sound like it could be that.
Originally Posted by pendy
I'm here for the D's
Old June 22nd, 2011, 09:34 AM
Naplm00
Matthew
I had this same whine when i bought my truck, it eventually turned into a rubbing/wobble noise. Replace the front wheel bearings (one was bone dry) and now im good to go
Old November 1st, 2011, 11:39 PM
Broncoduecer
peter
D90
Hi again guys,
So Tonight in the garage I put each wheel up on a jack and tested for any play. The drivers front and passenger rear both had play. Not in and out play, but if you grab top and bottom or side and side and "push pull" you can get play. So two wheels were fine and two weren't, is this a symptom of wheel bearings or something else?
I thought if dealing with the fronts it could be something else, ball joints (swivel pins?), from dealing with fords, but the rear. Well yea, nothing else to move back there. Just looking for a sanity check.
As for bearings are the timken better than the genuine?
Pete
Old November 2nd, 2011, 07:39 AM
repace all your wheel bearings asap! get parts on hand quick and go with newer double lipped seals and new style locknut!
Mark Kellgren
KM4BOR
Old November 2nd, 2011, 10:10 AM
Broncoduecer
peter
D90
Sounds like a plan. Does RN have the new seals and nut? Are both inner and outer seals new or just one side?
Pete
Old November 2nd, 2011, 10:30 AM
same seal for inner and outer on each hub. I run wet hubs on all 4 so I only need 4 seals. If you run dry hubs you need 8 seals (inner and outer). yes, RN has it all. I just ordered a full set myself a few weeks ago for a concerning squeal, but turned out to be a bent mud shield was making the noise, so now I have the new locknuts ready to go when the time comes, and have an emergency bearing kit in my rig with a new seal, new packed bearings in a ziploc, and a new locknut.
A few years ago on my way to KY from NC, I had a bearing seize on me in TN. I didn't accept it soon enough and ended us seizing the bearing on the highway. $1500 to LR dealer for a new hub and bearings, when this kit with less than $50 in parts and the right set of tools was all I needed, and could have been done in a hotel parking lot in a couple hours.
ht, wheel
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
» Defender Registry
Hot Water
Wilboro
Mancar
emah
Add your Defender
