Ride Height Measurement - Defender Source
Old July 22nd, 2010, 06:47 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Can anyone running 315/75s on a 90 or 110 measure from the ground to the bottom edge of the wheel flares or to base of the sills? I am trying to determine what height lift I currently have.
Semper Fi!
Old July 22nd, 2010, 09:51 AM
Wouldn't it make more sense to measure the hub center to wheel arch lip? Are you measuring suspension lift or overall lift including that provided by the larger tires? If so, at what pressure?
Old July 22nd, 2010, 11:04 AM
Wolf Fabrication
Sterling Archer
'08 D3
I just need a measurement, I don't care where it starts or stops. I am trying to determine a baseline on my current lift, so I would need to know what size lift the truck being measured has. Normal TP, 35ish psi is fine.
Semper Fi!
Old July 23rd, 2010, 10:44 AM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I measured to the bottom of the wheel flare and I have 37 3/4" in the front and 38" on the rear. That is with OME heavy front and medium rear and like 32ish PSI.
Old July 23rd, 2010, 02:13 PM
Wolf Fabrication
Sterling Archer
'08 D3
Interesting. I measure 37.25 front and rear with unknown springs. Sounds like I am likely about a 2" lift or so. Just wanted to get a baseline before I "spring" for a 5" lift.
Thanks!
Semper Fi!
Old July 23rd, 2010, 03:48 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
I've always thought my truck looked lower than every other truck with identical springs. Not sure if I have more weight or what.
That said, the suspension gives me lots of travel. So even though I don't have the appearance of a 2 inch lift, when the wheels need to go up and down, I get plenty of travel.
Old July 24th, 2010, 07:43 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will measure mine later for ya..
Legend in My Own Mind.
Old July 24th, 2010, 09:58 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thanks!
Not that I want this to turn into a suspension thread, but if you put a 5in lift on a defender your anti-squat would be so rediculously high that I doubt it would wheel worth a crap. I know you like to wheel so I thought I would throw that out there. I'm no help on your measurements.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
ht
Actual lift measurement with OME KevinNY Defender Technical Discussions 1 February 2nd, 2006 04:18 PM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
Dad's Last Ride gowyn Misc. Chit-Chat 9 June 22nd, 2005 08:52 PM
Hitching a ride to Cityside Garage artm Defender Technical Discussions 1 December 14th, 2004 03:37 PM
Pimp Yo Ride Mike Hippert Misc. Chit-Chat 11 June 4th, 2004 10:35 AM
