rhino lining - Defender Source
Old December 8th, 2004, 08:34 PM
jperakis
James Perakis
94 ST
rhino lining
hey guys so im gettin the whole interior rhino lined this friday and i just began the prep work (ie pulling everything out), my question is should i leave the foam whatever you wanna call it that surrounds the seat boxes on? im tempted to just rip it all out.
Another question for those who have any lining in their 90, what about all the screw holes, or bolts? 1. will the lining completly cover those holes? 2. will the lining make it impossible for me to remove any bolts that have been coated?
Old December 8th, 2004, 09:00 PM
Hey James, I ripped that stuff off, but the glue holding it is a real pain to get off, I ended up grinding it off. As for the screw holes, if it is Rhino lining then you need to tape them off or you will have to run a tap through them to clear them out.
Old December 8th, 2004, 09:32 PM
I decided not to rhino-line, its just too indiscriminate for me. Instead I'll eventually get that molded rubber lining that you can get from LR. You see it on ebay sometimes in RHD format.
For those of you with Rhino -Liner. Quimbola Defender Technical Discussions 2 January 22nd, 2009 03:23 PM
Rhino Lining boshea Defender Technical Discussions 7 November 4th, 2004 08:55 PM
Rhino Lining a defender Dfndr90 Defender Technical Discussions 13 August 6th, 2004 08:52 PM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
rhino lining for fiberglass hardtop CHRIS C Defender Technical Discussions 7 March 28th, 2004 10:47 PM
