Rhino Lining - Defender Source
Old November 3rd, 2004, 02:28 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Rhino Lining
Has anyone out there rhino lined their vehicle? I am interested in rhino lining the rear cargo area and was wondering how it holds up..how easy it is to maintain...and how it looks. Any pictures would be greatly appreciated.
Thanks guys!
Old November 3rd, 2004, 02:43 PM
I'm considering doing just the seatbox. I dont like the indiscriminate nature of a lot of applications, but I want to do it as a replacement for the crummy vinyl which is falling apart.
I went to the local RL place and it appears that some dealers offer far more services than others. This place is only interested in doing about 5 colors, whereas the website claims they can do color matching and stuff. It doesnt matter, because black suits me fine.
I looked at some of their work and it looks good, kind of a semi-gloss heavy-texture surface and they can spray it as thick or as thin as you want.
Thats all I know.
Old November 3rd, 2004, 06:26 PM
http://www.defendersource.com/forum/...ead.php?t=2959
Old November 3rd, 2004, 11:19 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
My brother opted to use similar on his J**p. Looks and works out good. He checked several sources for coatings and advised that Line-X is supposed to be better. I have heard that if you use colors they will fade if un UV.
Old November 3rd, 2004, 11:24 PM
I welded up some sliders for the rig about a month ago and had them Line-Xed. Very tough stuff! The guy at the Line-X place said that after 24 hours the only way to get the stuff off is with a grinder. If I was going to coat the inside, Line-X would be my choice.
Old November 3rd, 2004, 11:29 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Hey . . .I wonder how it would look to Line-X the door sills (where the pan shows) I have been trying to decide what to do there as I dont really like the look even though it is "original"
Antone ever coat that area?
Old November 4th, 2004, 02:54 PM
discocolo
Jeff Pearson
Sorry to get off the subject guys, but Larry did you put the carpet in your truck? Just curious. If you did, where did you get it from. If not does anyone know the best way to carpet one that doesn't have carpet?
Jeff
Old November 4th, 2004, 08:55 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
Got from Rovers North They can get all sections. Ask for Arthur he will make you good price on ordering sections all at one.
New carpet seems to be a bit nicer than the original and color is same.
For those of you with Rhino -Liner. Quimbola Defender Technical Discussions 2 January 22nd, 2009 03:23 PM
rhino lining jperakis Defender Technical Discussions 2 December 8th, 2004 09:32 PM
Rhino Lining a defender Dfndr90 Defender Technical Discussions 13 August 6th, 2004 08:52 PM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
rhino lining for fiberglass hardtop CHRIS C Defender Technical Discussions 7 March 28th, 2004 10:47 PM
