worked this up as a post in the other thread but as poor as the search engine is....well thought cross posting with a title might help other in the future.
Bottom line is prices have dropped on a lot of these parts as LR abandon's the production of them and the secondary market jumps in.
Gray dash/backer panel $206. Many have painted these black with plastic paint sold by home depot etc- looks pretty sharp.
MTC4617LDQ
http://www.brit-car.co.uk/product.ph...ment_facia_def
Update 1/22 this part now made for Rovers North
The parcel tray is MRC7283 $28
http://www.johncraddockltd.co.uk/lan...-wa159806.html
The lower dash lip piece $11
http://www.brit-car.co.uk/product.ph...y_lhd_defender
The under binnacle stiffener panel is easily converted from RHD to lhd by enlarging the cut out. $63
the part is a bit pricey for a stamped bit of steel
MUC7599 | Stiffener - Paddock Spares
The lhd instrument binnacle $125
LAND ROVER DEFENDER 87-98 INSTRUMENT MOUNTING SUPPORT PANEL MTC5459 NEW | eBay
grab/entry grip @ end of dash $63
MTC6142 | Grab Handle - Paddock Spares
Heater control end cap $13.50
http://www.brit-car.co.uk/product.ph..._facia_lhd_def
LHD heater fan speed control $72
Heater Control LHD (Britpart) BTR4434 UTP1925 STC4849 Island 4x4 - Specialists in Land Rover and Range Rover Parts and accessories for all models. UK and worldwide mail order.
LHD heat/defrost controls- expensive @ $210
http://www.johncraddockltd.co.uk/lan...and-90110.html
Lower dash/heater duct still pricey @ $1575
Duct - Heater
With some time and a little skill a lower dash/ heater vent can be converted from rhd to lhd for little to any expense
the rhd steel dash support piece is easily cut to work in a lhd application
The upper dash "crash pad" is the same part left or right drive
Right now with these knock off parts now available a complete (new)lhd dash can be bought for $2366 plus shipping. As I said several of these parts can be converted and the end cost would be less than $800 plus the heater if you can modify those parts. Safari HP has the lhd heaters on sale to complete the conversion. The shorter wiper curved tube part is less than $30 and the wiper motor gear can be phased 180 degree's to change the side it stops on. The bulkheads can be converted from right to left with a drill, 4.5 cutting wheel, a rivet gun, and some steel plate.
The heater's can also be converted and you would need the lhd blower motor (suggest the gm version) and the stamped fan housing part of the heater box sold separately. Forum member Mike Sandone did a nice write up on how to do it somewhere- perhaps someone could link his write up.
MTC4617LDQ
Fascia Panel For Dash Vents Defender LHD PLY011 | Rovers North - Land Rover Parts and Accessories Since 1979
High quality OEM injection molded plastic fascia panel that fits into the upper dash to conceal the defroster hoses and fresh air vents in Black. FITS: Defender Left Hand Drive 1983-1997 pre Td5 with front mounted fresh air vents Additional Images: Fits These Vehicles...
www.roversnorth.com
Duct - Heater
