RHD to LHD conversion question - Defender Source
Old January 8th, 2006, 09:14 AM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Has anyone done this? I am getting a RHD d90 with 2.5L NA diesel and am looking for experience and a complete parts list...anyone?
thanks
George
Old January 8th, 2006, 10:36 AM
i think you would have t start with the bulkhead and move a shitpile of stuff around in the engine compartment steering heater box why not just keep it on the right side. It doesnt seem cost effective, it might be easier to just get a LHD Defender
Old January 8th, 2006, 11:00 AM
I depends on how you get the parts. If you order them all from RN it will cost a fortune, buy used and it will be better. The bulkhead can be adapted, but its work - cut new pedal holes, close the old ones, switch the wipers over etc. Obviously you need lots of LHD dash parts... Also, you'll need a new steering box, pahhard assy. and probably also have to swap out the RH swivel ball housing for a LHD part so you can attach the drag link.
Old January 8th, 2006, 04:10 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I did this conversion starting with a LHD bulkhead. All the dash stuff is different and I mean all of it. Also, the entire heater assembly is different. You need a LHD steering box and like 2 brackets. IF your axlew does not have the steering bracket on the opposite swivel, you will need a swivel housing.
You can reuse the steering column and all the pedels. Oh and you need new brake lines and clutch lines too. The most expensive stuff is the dash parts though. what year is the truck? I have all the part #'s if you need things and a good sorce for parts in the UK to get you everything..
From my experience I would get a new bulkhead though and start from there. they are only like $350 and no rust or mods to deal with. I even Galv mine then painted it so it will never rust.
Legend in My Own Mind.
Old January 8th, 2006, 07:05 PM
Gkase's Avatar
Gkase
George Kase
thanks Randy
Thanks...I'll PM you for the details...
George
Old January 8th, 2006, 08:35 PM
I've also got some LHD dash parts I can sell you if you want - they need to be fixed up with POR-15 and maybe some vinyl, but it would be a cheap place to start.
Old January 8th, 2006, 09:47 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
thanks
George
Why do you want to convert it. The only good reason I could think of would be being able to use the drive up windows at fast food joints. I have a RHD and love it. Took me about 1 hour to get used to it. I say keep it the way it is.
Old September 12th, 2008, 10:22 AM
http://www.dividingcreekroverimports.com/d...rive_conversion
Old September 12th, 2008, 10:36 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Looks great!
Nice illustrated write-up! So.... How much time (roughly) did it take you to install all the parts?
Was any part hard to find?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 12th, 2008, 10:48 AM
Gkase's Avatar
Gkase
George Kase
Kevin,
my post was from 2006...project long dead.
George
Old September 12th, 2008, 10:51 AM
Loic,
A bunch. Probably have close to 25 hrs into this. Part of that was figuring it out as I went along. If some one was going to tackle this I would allow for two full weekends. I did this while tearing the truck apart for a repower so my project had an empty engine compartment which made it easier. Swaping out the front axle by yourself is a job.
Swapping the steering knuckle would be the easy way to go but I wanted to upgrade to 24 spline.
I didn't mind rhd but since it was apart and I intend to add a/c the time was right.
Still finishing this part of the project up and will go back and clean up the write up and add some pictures. I got the a/c system out of Charles Galpin's 90 on Tuesday and will go ahead and install that as well. I also swithced all of the gauges except the speedo to VDO (added an EGT and dumped the amp/voltmeter temporarily).
I had no trouble sourcing any of the parts. You re-use the dash top pad. The pre-bent brake lines I special ordered from Rovers North. Every Monday after three they place an order to the UK. If the part is in stock in the UK they have it by Friday. I had the lines the following Monday. George @ RDS had most of the dash parts (all that I needed) in stock.
Old September 12th, 2008, 08:31 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Great pix Doug. I would just point out that not all bulkheads are precut for the pedals on both sides. Mine was rhd specific but it did not matter since i changed my bulkhead over to a nice new galv. one when I did my conversion. Maybe just the early bulkheads were like this. As for the front axle, I found a 24 spliner as well and it actually had rhd and lhd knuckled on it which was cool. I think later style axles came with these but im not sure..
Old September 12th, 2008, 08:45 PM
Randy,
I know the later bulkheads are definately sided-although they too can be converted with just a little more effort. I haven't imported anything but 83's so I'm not sure when the changes were made. An axle with both right and left steering knuckles- that was a find. Do you recall what it was out of ?
Old September 13th, 2008, 04:36 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Originally Posted by Maryland 110
Randy,
I think all the later axles are that way.
Mike Hammond
Old September 14th, 2008, 08:01 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Doug, I actually bought my axle brand new in a crate from the the US Government. It was a 2002 vintage. Also picked up a 1.4 t-case at the time. got them both brand new for $1500 shipped. It was a deal and a half.
The guy told me it was left over stuff from a project they were doing with TD5 stuf. They only used the motors but had all the other drive train stuff for sale.
conversion, lhd, rhd
RHD / LHD Td5 Dash Kits New Take Off FS SafariHP The Vendors Loft 11 September 26th, 2013 06:29 PM
Question about LHD VS. RHD Turbofan Defender Technical Discussions 6 August 31st, 2009 04:58 PM
RHD to LHD conversion evilfij Defender Technical Discussions 1 December 8th, 2006 02:21 PM
RHD vs LHD drop arm azD90 Defender Technical Discussions 0 July 16th, 2006 08:57 PM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
