RHD to LHD conversion - Defender Source
Old December 8th, 2006, 11:32 AM
Hello All,
Sort of a long term plan, but what is needed parts-wise for a RHD to LHD conversion of an 1984 110?
My biggest concern is interior and electrical. Do I need a new harness or will the one I have work?
Interior questions:
It looks like the dash is not handed except for the grey backing plate, the grab handle on the passenger side, the trim piece on the edge of the shelf, and what else ??????
Stuff I know I need and have:
LHD axle assembly complete.
Panhard rod???
Panhard rod bracket
Steeering box (will a 4 bolt box fit to a three bolt collum)?
Stuff I need to do to the frame:
Weld on damper mount.
Weld on panhard mount holes.
Drill for LHD steering box and sleeve holes.
Stuff I need to do to the bulkhead:
Cut holes for clutch and brake pedal boxes on LH side (maybe patch heater holes?)
Patch holes on other side and fit heater holes in place.
Drill for steering colum???????
Can I take the gear shifter off and reposition like on an R380 (it has an LT95) or do I need to bend or buy a correct LHD one?
I don't care about the parking brake. I prefer it on the other side.
Stuff I don't have:
Brake lines
Clutch lines
anything interior
anything electrical
How much time should this take? Could it be done in a week?
A website detailing the project would be great.
Old December 8th, 2006, 02:21 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
You can make your harness work with mods. Wiper motor wiring, brake light switch wiring etc. You have to shorten some wirea and make others longer, but it can be done.
A lot of Defender frames have all the mounts for either RHD or LHD, unless its a really early frame you shouldn't need to do any fab on the frame.
The upper dash pad is uni-sex, but the lower dash pad, the wiper motor cover, the insert and even the dash face is different. The gauges are the same, but not much else in the dash.
Most axles are uni-sex, you just use a LHD panhard rod and such and you'll need the RH swivel hosuing for the drag link pick up.
Don't forget a new heater. If you have all the parts it can be done in a week. Usually some small part will trip you up though and it takes longer.
Email:
conversion, lhd, rhd
RHD / LHD Td5 Dash Kits New Take Off FS SafariHP The Vendors Loft 11 September 26th, 2013 06:29 PM
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
Are there LHD and RHD transmissions? jessejames4 Misc. Chit-Chat 10 January 11th, 2008 02:03 PM
RHD vs LHD drop arm azD90 Defender Technical Discussions 0 July 16th, 2006 08:57 PM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
