RHD drop arm - Defender Source
Old July 26th, 2010, 02:32 PM
sundogcwolfe
Charles R. Wolfe
1984 110, 300Tdi
RHD drop arm
need right hand drive drop arm for defender. Any one got one?
Cwolfe
Old July 26th, 2010, 02:36 PM
same as lhd but yes I have a couple that will probably need rebuild kits.
Old July 26th, 2010, 02:44 PM
draaronr's Avatar
draaronr
Here
LR3
I think they are keyed different.
Old July 26th, 2010, 04:27 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Different part #'s for LHD & RHD
Old July 26th, 2010, 05:31 PM
WLDKGDM's Avatar
WLDKGDM
Dan Cronin
1997 D90 SW
Two different parts.
RTC6398 - POWER STEERING DROP ARM RH
RTC6399 - POWER STEERING DROP ARM LH
Log on to LRSeries.com and they have them there.
Wear The Fox Hat.
Old July 26th, 2010, 08:48 PM
I'm aware the parts books shows two different part numbers, I spend lots of hours in those books weekly. That said a 1983 rhd drop arm slides right onto a mid 90's lhd power steering box. If the drop arm is centered, the steering wheel centered, and the front wheels centered when its all assembled I don't see what the difference is that matters. The test is when going down the road and it all self centers. Now the thread in part that goes into the steering arm thats a totally different casting and has to be changed. This is one of the few parts I don't order new when doing a conversion>well this and a panhard rod which also shows as being sided. Figure that one out, no key ways on those nor are the bushings different.
I'm perfectly will to be wrong but having done a bunch of lhd conversions...........
Educate me and show me the error of my ways.
Old July 28th, 2010, 05:52 PM
sundogcwolfe
Charles R. Wolfe
1984 110, 300Tdi
So is there a difference between the drop arms on a three bolt versusm4 bolt power steering box?
Cwolfe
Old July 30th, 2010, 06:26 PM
Been a crazy week but finally got a chance to crack open the parts catalogue. It seems they may differ (compare to your vin to be sure).
LR110 up to August 1986
3 bolt (Adwest heavyweight) to vin 243977 rhs
Drop arm RHS NRC8556 (NLA use RTC6398)
Drop arm LHS NRC8557 (NLA use RTC6399)
4 bolt (Adwest lightweight) from vin 243978 to vin 256704 rhs
Drop arm RHS RTC6396
Drop arm LHS RTC6397
rhd
Discovery I drop arm on D90 box?? nikojo Defender Technical Discussions 1 March 20th, 2009 12:11 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
RHD vs LHD drop arm azD90 Defender Technical Discussions 0 July 16th, 2006 08:57 PM
Drop arm! TwisteD90 Defender Technical Discussions 9 July 19th, 2005 09:27 PM
Steering drop arm kellymoe Defender Technical Discussions 12 November 7th, 2004 02:07 PM
» Defender Registry
Lang
Langley90
110
Mes788
Add your Defender
