RHD 300tdi Snorkel install - Defender Source
Old October 3rd, 2013, 10:37 AM
vlocci
Vin Loccisano
I'm trying to add a safari style snorkel to my 1984 RHD 300tdi and am running into some issues.
I don't have a cutout in the right (or left for that matter) fender but can pretty easily rectify that. I'm struggling with what happens after I get through the fenderwell. This gets a bit more complicated as I have a webasto and AC under the hood as well.
Anyone install a fender mounted snorkel on a RHD 300tdi and willing to snap some pictures of your hose routing?
Any suggestions on where to buy?
Vin
Old October 3rd, 2013, 11:43 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Vin
why not go through the wing top if your sides are uncut?
Old October 4th, 2013, 11:28 AM
vlocci
Vin Loccisano
The answer is entirely cosmetic. I like the look of the safari snorkel style of extended intake.
Vin
Old October 4th, 2013, 11:32 AM
Do you have the original plastic intake box that mounts to the inside of the wing? There is a flex hose routed frrom the intake box to the air filter canister.
You need one of those first to mount the snorkel.
Old October 4th, 2013, 12:01 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
What is a "safari style" snorkel?
I only ask because if it's a Mantec solid ABS plastic type, there is a certain way to mount that and if you have a flexible lower portion (like the one I have), that may require a different cut-out and routing.
Post some pictures of what you're looking at (I assume you have an ROW truck with no cage).
I had to swap my solid Mantec one for a flexible one because of the SD cage.
For those wondering why there is a black backing plate riveted to the fender, it is because the other snorkel that came off had a real hack-job cutting out the incorrect placement and the new mount was too small for the existing hole. It was either source a new wing panel, paint it and install that or make a backing plate. Since I had just been ass-raped by ECR, I opted for the cheaper fix.
Name:	Snorkel Finished-11.JPG
Old October 4th, 2013, 01:11 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Vin
Post up a pic of the look you are after...
Old October 4th, 2013, 01:39 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Never understood why some people go for the plastic Safari Slug instead of the nice Mantec steel raised air intake. Why would you want to cut up your vehicle for a crappy piece of plastic?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old October 7th, 2013, 09:03 AM
vlocci
Vin Loccisano
Gents,
Looks like a Safari snorkel is out, as my Webasto engine heater is in the way and I rather not spend the effort to relocate it.
Can anyone point me toward a through the top of the wing style snorkel? It seems like Mantec (who I have used in the past) no longer offers this model. Is there an equivalent?
Vin
Old October 7th, 2013, 09:15 AM
IMO Southdown do the nicest one.
Old October 7th, 2013, 09:19 AM
rovertrader's Avatar
rovertrader
Dale
I have a SS Southdown if you are interested-PM if so.
As far as the Mantec version through the top wing vent, RN still has them...
Old October 7th, 2013, 09:47 AM
vlocci
Vin Loccisano
Is the southdown through the fender (requiring cutting?)
I tried Rovers North, but need a snorkel for a RHD. No luck apparently
Vin
Old October 7th, 2013, 09:53 AM
rovertrader
Dale
Yes, the SD sits on the top radius edge of the fender and is ambidextrous so fits either RHD/LHD...
The RN would only need to be adapted to fit the right wing top vent I think. Could even cut the one on it off, and flip it over if you have welding access.
Old October 7th, 2013, 10:01 AM
1-AW3.5R
Mantec makes a wingtop one that does not require cutting.
The Southdown snorkel is ok, but, again, routing an intake into the side wing is a major PITA.
I have the original wing-side intake for my RHD 200tdi truck if you want it.
300tdi, rhd, snorkel, tdi
Snorkel Install Glenn_Guinto Defender Technical Discussions 7 December 31st, 2012 09:51 PM
RHD 300tdi air conditioning options vlocci Defender Technical Discussions 3 July 16th, 2012 03:42 PM
Mantec Snorkel and Custom Plenum Install Jackie Treehorn Smaller Projects 1 February 11th, 2012 03:44 PM
1984 300Tdi D90 - RHD GreenRover For Sale - Vehicles 49 November 30th, 2011 06:09 AM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
