RHD 19j -> 300tdi. Power steering questions. - Defender Source
Old May 9th, 2015, 12:05 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Hi folks, just started ripping apart my ROW RHD 110 and wanted to tackle the power steering line issue sooner than later. My RHD unit has the power steering unit on the right hand side of the vehicle with appropriate lines connecting to the 19J pump.
A quick inspection shows that the 300TDI lines that are on the engine are much shorter and I'm assuming for a unit that's on the LH side of the vehicle.
Questions:
Are the OEM parts that allow for a 300TDI to use a power steering unit/rack on the RH side? If so, what are those part numbers?
If not, I'm guessing custom lines?
Thanks!
Old May 9th, 2015, 01:41 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
There are RHD lines and LHD lines for the PS unit for the 300tdi - different part numbers
RHD - ANR2485, ANR2135, ANR3598
LHD - ANR2485, ANR2136, ANR2487
Old May 9th, 2015, 10:12 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
Thanks for those PNs. It looks like my engine's got a fresh ANR2485 on it. From looking at the diagram, I'm struggling to see where that hose goes. It's obvious it's a low pressure line, but the other two PNs listed run to the resevoir and power steering box.
The last numbers listed make up pipes #1 and #3. I don't see where/how the first PN fits in the picture?
Thanks for your help!
Old May 9th, 2015, 10:23 AM
the rover shop
shayne young
Only number 3 is a high pressure line.. The rest are returns or supply lines, so can be regular hose.. Number 3 is the only one that needs to be made.. And any hydraulic hose company can make it cheap..just take both ends and tell them how long you want it..
Old October 24th, 2016, 05:27 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Bumping this thread. Does anyone know specifically what type of flares the power steering box (for a 19J) and 300tdi pump use?
300tdi, rhd, tdi
19J smoking and low on power tijnes Defender Technical Discussions 3 March 28th, 2015 09:34 PM
Best Power Steering Gear Box RHD? Rosproline157 Defender Technical Discussions 2 May 30th, 2012 03:07 PM
Defender RHD Power Steering Box John_Karlsson Wanted 7 September 27th, 2010 01:40 PM
RHD Power Steering Kit (( Take Off )) SafariHP The Vendors Loft 0 July 8th, 2009 09:05 AM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
