Review Photos for D90 Purchase & Technical Q about reinstalling windows - Defender Source
Old June 12th, 2013, 11:47 PM
Dragon Breath's Avatar
Dragon Breath
Jay
Blank
Hi All,
Very similar request to what blaughva recently posted. Could you please review these photos (94 ST) and let me know if you see any areas of concern or anything that you view in a positive light. This is my first D90 purchase also, so any input would be greatly appreciated.
The owner said he had the front windows taken out permanently and says he has all the parts, but doesn't know whether the vehicle was modified or whether body work would need to be done to put the windows back. Is there any possibility they could have permanently modified it so that I won't be able to get the windows back in place -- or is it so straightforward that permanent damage is doubtful. (See pics re where post holes were filled in with plastic anchor and screw.) If he hadn't said anything I would have assumed I could just put them back, but now I'm concerned.
Thanks!
ID:	74325   Click image for larger version
ID:	74327   Click image for larger version
ID:	74329   Click image for larger version
ID:	74331   Click image for larger version
ID:	74333   Click image for larger version
Old June 12th, 2013, 11:49 PM
Dragon Breath
Jay
Blank
More Photos
More photos
ID:	74335   Click image for larger version
ID:	74337   Click image for larger version
ID:	74339   Click image for larger version
ID:	74341   Click image for larger version
ID:	74343   Click image for larger version
Old June 12th, 2013, 11:50 PM
Dragon Breath
Jay
Blank
Last set of photos
last set of photos
ID:	74345   Click image for larger version
Old June 13th, 2013, 02:25 AM
Doors are split and the sliding windows do come out. The holes are for the posts that secure them in place.
Where is this truck located and how many miles. Looks incredibly clean. Only puzzle is the yellow paint on the chassis.
What's the vin?
Old June 13th, 2013, 07:51 AM
Need pics of bottoms of doors, better shots of the footwells with the mats fully removed (photos supplied do not show where the corrosion usually is), additional photos of the bulkhead from the engine bay, and some shots up at the bottom of the footwell up through the rear of the driver and passenger wheelwells . Also need additional photos of the rear crossmember, which is one of the only spots I see some little rust starting. The rear crossmember is delaminating (which is common). This is a snap shot of the area I'm talking about - these sheets of steel should be sandwiched together tightly. Taken from your photo 11 of 23.
Old June 13th, 2013, 08:58 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Are these plugs a LR part? Any idea on where to find them?
Old June 13th, 2013, 09:30 AM
Dragon Breath
Jay
Blank
More Photos
Thanks for the input so far -- this truck spent its life out west and has approx. 75k miles (I say approximate because the carfax includes a reference to a not actual miles title being issued. That said, the other carfax entries suggest the mileage is in the ballpark.
I neglected to mention two other things. 1. The a/c fan works, but it's not blowing cool air -- so I have no idea whether that's a $1700 repair or a $100 fix. 2. The owner has a Badger II top on order -- says it's been on order for months.
I am posting all the other photos I took and hopefully they'll give you enough to weigh in further. (I didn't notice any yellow paint on the chassis, not sure if it's just lighting or a reflection.) Again, thanks!
ID:	74356   Click image for larger version
ID:	74358   Click image for larger version
ID:	74360   Click image for larger version
ID:	74362   Click image for larger version
ID:	74364   Click image for larger version
Old June 13th, 2013, 09:31 AM
Dragon Breath
Jay
Blank
Final Photos
This is the last of the photos.
ID:	74366   Click image for larger version
ID:	74368   Click image for larger version
Old June 13th, 2013, 09:37 AM
Dragon Breath
Jay
Blank
Perhaps someone can answer your question, but because the photos aren't sharp I wanted to let you know it looks like it's a black plastic anchor and then a black Phillips head plastic screw.
Old June 13th, 2013, 09:39 AM
Nothing is telling me to run, so go for it. Don't let those door top plugs be a deal breaker. If that's your biggest concern, then continue on with the buying process on this truck. If it REALLY seems like it's a big deal, then maybe start looking for a Toyota insterad, because there will certainly be bigger issues than those little door plugs down the road.
Old June 13th, 2013, 10:25 AM
down_shift's Avatar
down_shift
Russell
Those rubber plugs are a great idea. Keep the water out from rusting the steel tubes.
Old June 13th, 2013, 10:35 AM
Josh is right. The pictures are dandy but do not show the real potential problem areas:
1. The footwell underneath the floor mats.
2. The bottoms of the doors.
3. Pictures of the bulkhead underneath the windshield frame.
Old June 13th, 2013, 12:09 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Buy the stainless steel door studs. Forgot who sells them but they are the way to go. And yes the studs are a LR part.
Jimmy Buffett
Old June 13th, 2013, 08:17 PM
Dragon Breath
Jay
Blank
Do I need any more parts than this to reinstall the windows?
Further to my question above, I now have a photo for the windows. Do I need anything more than these posts to reinstall -- or are there other parts? Note damage to the sleeve on one of the posts -- not sure if that will creat problems and/or whether these parts are easily replaceable. I also see a little rust near the post hole on the top of the right window. Thanks for your answers!
Old June 13th, 2013, 08:22 PM
Don't use those posts/studs - as others above said get the stainless ones. Nothing to worry about.
Old June 13th, 2013, 08:23 PM
That is as rust free as 20 year old defenders come. The plugs for the window studs probably pop right out. The fact the guy put them in makes me think he is really anal which is a very good thing. Depending on price I would buy it as the condition looks excellent.
------ Follow up post added June 13th, 2013 08:24 PM ------
Other than nuts for the bottom of the studs, you need nothing. I bet they are in a bag somewhere in the truck.
Old June 13th, 2013, 08:27 PM
Dragon Breath
Jay
Blank
Thanks guys -- I didn't realize the reference to studs was the same as what I referred to as posts (glad you clarified). I've made an offer and am waiting to hear back. Much appreciated!
Old June 13th, 2013, 08:43 PM
bjf's Avatar
bjf
barry f
94 ST #395
He didn't show the normal trouble spots but I agree with Ron. The truck looks rust free. There is no way to get axles that clean with grease pen marks if the rest of the truck is rusty. The ac could still have caused rot but it appears to be owned by someone who looked after it.
d90, windows
WONDERING IF I SHOULD PURCHASE A LOCAL D-90 please help jchan88 Defender Technical Discussions 8 November 24th, 2004 07:46 PM
message to SCOLOCO - side step photos? paulb Defender Technical Discussions 0 August 18th, 2004 04:05 PM
ST windows slide Cyborg Defender Technical Discussions 3 May 10th, 2004 12:50 PM
More Softtop Help - 97' Windows jbird Defender Technical Discussions 2 April 27th, 2004 11:39 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
