Reverse Switch - Defender Source
Old May 24th, 2011, 09:10 PM
dimcon
Chris Goldie
94 D90
Reverse Switch
I need some help locating the reverse switch on a 51A LT77. I pulled the switch from my V8 77 60A but there is
not a corresponding hole on the 51A.
Also in the rear harness there is a 12 ga (maybe) purple wire that runs front to rear. I can't find this wire in the diagram I have. My harness was damaged and I'm redoing it, but I have all the lights covered and a wire for future rear fog/work light. Any help would be great.
Old May 24th, 2011, 09:29 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
If my memory serves me correctly, I believe it is located on the top area of the tranny aft of the shifter. I believe it is a screw in switch. Accessing it via the floor access -- below the center console -- might make things a bit easier (I'm not certain what a 51A is?).
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 25th, 2011, 06:48 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Purple wire from the front to the rear should be a Power feed. Reverse switch on the R380, don't know the LT77, is on the LH side.
Land Rover 110
Old May 25th, 2011, 09:13 AM
Naplm00
Matthew
lt77 is on the top begind the shifter with the electrical spades facing the rear of the truck
Old May 25th, 2011, 05:59 PM
dimcon
Chris Goldie
94 D90
[QUOTE=MC22958;283311]Purple wire from the front to the rear should be a Power feed.
Power feed for what? Where does it connect to?
------ Follow up post added May 25th, 2011 06:02 PM ------
51A, best I know is the serial number prefix. Earlier model or for my use a diesel version of the 77. The V8 one I have is a 60A. The switch from the V8 was a screw in type, just where you said, but there is no no hole in the same location on the diesel trans.
Old May 25th, 2011, 08:15 PM
dsh12
Daniel Hayes
Isn't a grounding switch?
Dan
switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
Reverse Lamp Switch Wiring fleabus Defender Technical Discussions 7 April 16th, 2006 11:58 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
