Reverse problems - Defender Source
Old October 25th, 2005, 03:04 PM
tmore
Tom More
1995 D90
Reverse problems
While backing up my D-90 it feels sort of like the e-brake is engage but when I start to pull forward it feels fine. When rolling backwards with the clutch pushed in it also feels fine, it only seems to bind/drag when in gear with clutch engaged under power.
Thanks Tom
Old October 25th, 2005, 05:12 PM
Monkeyboy
Guest
Posts: n/a
Hi Tom,
My '94 Disco was making a funky noise while backing recently too.
I took off the rear driveshaft , put everything in neutral and spun the e-brake drum frontwards and backwards ... guess what? It only made the goofy binding noise spinning backwards.
You can either back off the adjuster until the noise goes away - at which point you have no parking brake, or replace the brake shoes, turn the drum/have it turned back to round, and clean up the adjuster bits.
My noise magically dissapeared and the park brake is actually back to a three click unit.
YMMV,
KAA
problems
ZF-4HP22 reverse slipping? kiphartzell Defender Technical Discussions 0 March 20th, 2006 09:30 PM
reverse gear... Gkase Defender Technical Discussions 1 September 29th, 2004 06:13 PM
Server Connection Problems chrisvonc Community News & Announcements 1 July 25th, 2004 10:22 PM
Hard to get into reverse Troys Defender Technical Discussions 4 January 11th, 2004 01:32 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
