Reverse Polarity Battery? - Defender Source
Old June 22nd, 2016, 11:37 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
I was at Batteries and Bulbs and they had what they called reverse polarity AGM batteries which the guy told me just meant the posts were switched. Is there any other difference between this and a regular battery? They were only $100 for the 775cca AGM which seemed like a hell of a deal.
Old June 22nd, 2016, 12:19 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Was the name of the company "Batteries Plus Bulbs" ?
RDavisinVA
Old June 22nd, 2016, 12:23 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
That seems a bit misleading. Usually they are referred to as Reverse Terminal and the Battery code will have an 'R' in it (like Group 34R - for reversed terminals). If this is all they are referencing, should be no other difference in the battery construction/specs/etc..
~Scott T.
'95 D-90 ST - AA Yellow
Old June 22nd, 2016, 05:24 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Here was the product number.
Old June 22nd, 2016, 05:25 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Could be. It's the green and orange logo.
------ Follow up post added June 22nd, 2016 04:29 PM ------
So is it just me or does that seem ridiculously cheap? The non-R Coded batteries were the same price as a cheap optima red top, 170 range
Old June 22nd, 2016, 05:37 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The posts are switched??? Can't you jist spin the battery 180 and have the same thing?
Old June 22nd, 2016, 06:42 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
The + and - are reversed relative to the side of the battery they are closest go. On batteries where the terminals are closer to one side of the case , the + and - will be opposite on the regular and 'R' models. No other diffs as far as I know. Doesn't matter if you cables reach, mount works, etc.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old June 22nd, 2016, 06:58 PM
Many battery groups have the terminals near to one side, so turning the battery 180 degrees puts them on the other side.
I doubt any of this matters on a Defender. On most cars the wires won't reach.
Old June 22nd, 2016, 08:15 PM
carlosz's Avatar
carlosz
Carlos
technically an acid filled battery does not have polarity once fully discharged. it is my understanding you can reverse the polarity of the terminals by fully discharging and slowly recharge.
never attempted my self, but if such is done then the larger terminal which once was positive becomes negative. also, you can connect two batteries in series pos to neg and obtain 24 volts, or parallel pos to pos and obtain higher amperage while mantaining 12 volts.
somewhat off topic but good to know.
Old June 22nd, 2016, 08:24 PM
You can but it will wreck the battery internals giving low capacity and short life as they are designed to work in one direction.
Old June 22nd, 2016, 08:31 PM
carlosz's Avatar
carlosz
Carlos
good to know...tx, now I know a second way to wreck a good battery other than fully discharge and recharge a couple of times..lol.
Old June 22nd, 2016, 09:59 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by RockShow View Post
Attachment 152397
The local store in Norfolk, VA has them for $182.
Wonder what the amp hr rating is?
RDavisinVA
Old June 23rd, 2016, 12:14 AM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
This store was in Waynesboro, Va
Old June 25th, 2016, 11:19 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I have two Odyssey batteries under my drivers seat. One is standard and the other has reversed polarity. The RP battery is mounted in such a way that one post is positioned under a metal brace. On a standard battery the hot post would be on that side and I didn't want any surprises if the hold down failed while I was driving off-road. The RP had to be special ordered directly from Odyssey.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old June 25th, 2016, 11:24 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Good idea---I've seen how you drive over rocks! LOL
Rent my
Old June 25th, 2016, 12:05 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
Whatever do you mean?
Battery switch outside the battery box suggestions rankar Misc. Chit-Chat 7 December 25th, 2014 03:13 PM
Reversing polarity on Jaeger amp meter? o2batsea Series Technical Discussions 1 September 9th, 2014 01:00 PM
Battery relay for dual battery install plus cables jonathon For Sale - Parts 1 February 3rd, 2014 07:36 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
