Reverse light wiring 300tdi? - Defender Source
Old December 26th, 2015, 07:52 PM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Red face Reverse light wiring 300tdi?
The reverse light and fog light on my 1999 TDi 90 LHD have no connectors to hook up, and no loose dangling wires..
Signals and brake lights all work.
There is one correct type receiving connector on the drivers side (fog) it's Black wire & Green with black stripe, But no power when reverse or fog. fuses all good to.
There are so many wires, some advice on the correct ones would be great! Thanks!
Old December 27th, 2015, 10:59 AM
4RF RDS
Kevin
2000 110 XS CSW
Do you have a wiring electrical schematic manual for MY1999? If you need one PM me.
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Old December 27th, 2015, 12:29 PM
If you don't have or want to find the wiring schematic, then find the reverse switch and check out the wire colours there. The switch is just below the shift tower. It should be a simple circuit. Power to the switch and then to the light.
300tdi, ht, tdi, wiring
Reverse light / fog light gremlins tim Defender Technical Discussions 10 November 1st, 2014 11:26 PM
Automatic Conversion Wiring for Reverse CDeWan Defender Technical Discussions 3 December 27th, 2012 10:53 PM
Reverse Lamp Switch Wiring fleabus Defender Technical Discussions 7 April 16th, 2006 11:58 AM
Help, no reverse light Glenn_Guinto Defender Technical Discussions 7 December 26th, 2003 04:17 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
