Reverse light troubleshooting - Defender Source
Old August 23rd, 2006, 09:12 AM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
No, it's not the bulb. Connections at the light are all fine, as is the fuse. Any suggestions on where to look in my troubleshooting?
Old August 23rd, 2006, 09:45 AM
tron's Avatar
tron
Thomas F
Recently Roverless
Probably not the problem, but mine was the casing/housing/cradle/grey plastic thingy, that the bulb plugs into. The leads on it were bad. You can just disconnect the old one and the new part is like $3 or something...if that is in fact the problem. Took me a while to figure it out (after replacing the bulb, looking at fuses, etc.).
Old August 23rd, 2006, 09:52 AM
btate
Bryan Tate
d90
Mine was the contacts for the bulb, a bit corroded. Are you getting power to the bulb assembly/wires?
Old August 23rd, 2006, 10:26 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
the reverse light switch in the gearbox could also be at fault or need adjusting or the connectors may have worked loose
Old August 23rd, 2006, 12:56 PM
loykd's Avatar
loykd
Ken Loy
I think Ian is on the right track. I shot wires at the bulb and I think they're ok. Just not getting the signal to turn on.
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Diff-Lock Light Reverse Logic???? MonLand Defender Technical Discussions 5 December 5th, 2006 12:31 PM
ZF-4HP22 reverse slipping? kiphartzell Defender Technical Discussions 0 March 20th, 2006 09:30 PM
Help, no reverse light Glenn_Guinto Defender Technical Discussions 7 December 26th, 2003 04:17 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
