Reverse light switch adjustments - Defender Source
Old June 18th, 2012, 04:01 PM
StphNieuw's Avatar
StphNieuw
Stephan
Former owner of a 84 D90 RHD 2.5 NA
Hi guys,
I am having some issues with the reverse light on my 184 ROW 90. When I put the car in reverse I see the light flash on for a second and go out right away this at least indicates that the bulbs and there isn't a short. Additionally if I move the gear lever over to the right once its in reverse and hold it there I can see the light stays on.
Question: can I address this by adjusting or is it a item that just needs to be replaced after all of the years of use? I thought they just screw into the thread and that's it. I haven't around to playing a lot with it but was hoping to get your inputs.
I also wasn't able to find many threads on the actual adjustment other than you adjusted it too far in preventing access to reverse.
-Stephan
Old June 18th, 2012, 08:51 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If I am thinking correctly it is a plunger type switch, AMR3918, for the R380. Your trans might be a little different. Might just be the switch is going bad.
Land Rover 110
Old June 18th, 2012, 09:24 PM
StphNieuw's Avatar
StphNieuw
Stephan
The part number is prc2911 for the lt77. British Atlantic had them for about 20 so I'll just order a new one.
ht, switch
Help! Reverse Light Switch Rosproline157 Defender Technical Discussions 4 April 30th, 2012 09:53 PM
Main light switch jchan88 Defender Technical Discussions 3 November 13th, 2005 09:43 PM
Help, no reverse light Glenn_Guinto Defender Technical Discussions 7 December 26th, 2003 04:17 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
