Reverse light(s) - Defender Source
Old May 18th, 2004, 12:14 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Reverse light(s)
I'm researching options for adding rear lighting to my vehicle ('97 D90 SW with/roofrack) and would like to hear other's experiences.
I'm planning to use the hella double worklamp EE Hella worklamp
but not sure what the best way to attach it to my rack is. I really like Wick's setup, shown here Wick's rack but am considering having two lights instead of one for more coverage.
I am also considering the possibility of mounting the lamps in a way that allows for removal of the basket while retaining the lamps and would consider welding tabs on if that is the best option.
I appreciate any ideas, comments and photos anyone has.
Feel free to post here or email me directly.
Thanks in advance.
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old May 18th, 2004, 01:00 PM
I have one of those mounted above my rear license plate. Very bright, just one in the back does as much as the headlights up front as far as flood area. If I can get everything wired back up tonight I can take a picture of the area that it lights up.
How often do you take your rack off?
Old May 18th, 2004, 01:33 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
I haven't had it off once since it was installed, but really only use it during the summer for camping and the annual trip to Moab. The rest of the year it's pointless to have it on and it's simple enough to remove and reinstall.
I love it when I need it, but want it off when I don't.
Arthur M Vigil
Colorado Native
Former owner of:
Old May 18th, 2004, 01:38 PM
I know you guys like spending too much money, but anyways, here is mine. Two PAR 36 rubber housed tractor lamps less than $10 US each. Work great wired in with the revese switch plus a parallel toggle switch to turn on for use as work lights.
Link to photo
Old May 18th, 2004, 01:42 PM
ronward's Avatar
ronward
Redsrover
None - sadly
John B., can you describe just how you wired the lights up? I like the idea of an auxiliary light coming on with the reverse light as well as through a toggle switch. Can you point me to a wiring diagram of such?
Old May 18th, 2004, 01:51 PM
I just ran wires from the lights to the stock reverse wires that are in the back access panels.
For the toggle switch you run the two wires from the switch to either side of the reverse switch (parallel to that switch). so when either switch is engaged the lights come on. As mine was ex-MOD, I didn't have a reverse switch so needed to run the wiring all from scratch, but it would be simple on a normal Defender.
For a toggle switch you need enough rating for the lights, so watch that. Also you should stay under the rating of the circuits involved. If you plan on going more than say 150 watts total, you should add in a relay.
I am using Contura 3 rocker switches. The reverse switch is the one on the left with the amber light. The light comes on with the reverse lights.
Old May 18th, 2004, 03:20 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Go to Keith and have him weld you a couple of light mounts. he did my old rack and I had two Hella FF100's on each corner and the tabs were welded to the ladders frame so if you decide to remove your basket you don't have to worry about the lights.
World traveler
Old May 18th, 2004, 04:24 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Thanks John. Is the reverse switch located behind the rear panel containing the reverse light?
Old May 18th, 2004, 04:32 PM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Hi Art,
I actually have a Hella worklamp on there at the moment. I'd rather have a Genuine unit, but for three times the price I went with this for now until I hit my next fortune. More important (IMHO) is the switching. Configured 3-way as the others to activate while reversing (really useful), but ising a proper 110 dome-light 3-way switch. Pictures follow...
Old May 18th, 2004, 04:33 PM
wicks's Avatar
wicks
Wicks
Light
wicks's Avatar
wicks
Wicks
1 more
Old May 18th, 2004, 04:38 PM
Not to Hyjack but Hey Wicks, I have a set of the Genuine Land Rover lights that are kinda like the ones in that pic. They are good lights but the reflectors are 1/2 rusted (I don't know why I just took them off my 90 and they are just sitting in the shed). They were rusted when I bought my 90 so i would say the Hella units will last longer.
Old May 18th, 2004, 04:45 PM
wicks's Avatar
wicks
Wicks
I might be interested in trying to salvage one of those...
Old May 18th, 2004, 04:49 PM
The reverse switch on mine is mounted at the back of the gearbox (LT77) facing backwards. Best accessed from the center seat access panel.
Old May 19th, 2004, 11:59 AM
howellm70
Michael Howell
Wicks - I've got a seperate but related question for you. I just picked up one of the hella work lamps and the D110 3 way switch - my question is what type of connectors did you buy to hook up to the round pegs on the back of the 3 way switch?
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old May 19th, 2004, 01:48 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Female bullet connector (.16?) can be spread apart enough to fit over the peg on the switch and the ground for the light itself.
Old May 19th, 2004, 02:38 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Mike Hippert - Sent you an e-mail on this subject.
Old May 19th, 2004, 03:01 PM
wicks's Avatar
wicks
Wicks
Yeah, I think they are yellow (that size) cable connectors that fit on the pegs.
Old May 19th, 2004, 04:15 PM
howellm70
Michael Howell
Thanks guys.
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
ht
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
ZF-4HP22 reverse slipping? kiphartzell Defender Technical Discussions 0 March 20th, 2006 09:30 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Reverse lights - brighter bulbs? RFA Misc. Chit-Chat 3 August 27th, 2004 08:01 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
