Reverse light NOT working - Defender Source
Old November 13th, 2013, 10:03 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
hey guys, I searched the forum and didn't come up with a solid conclusion to this small issue. My reverse light on my 110 doesn't turn on when put in reverse on my R380 trans. I tested and theres NO 12 volt power going to the light. Sorry if this is a redundant topic, just need trouble shooting steps to eradicate this issue.
Detail:
1993 110 with R380 trans, no voltage to the reverse light.
Thanks for your help.
Old November 13th, 2013, 10:10 PM
Is there power going to the switch on the transmission?
If so, then you need a new switch.
If not, your problem is between the fuse box and the switch.
Old November 13th, 2013, 10:14 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Originally Posted by javelinadave View Post
Is there power going to the switch on the transmission? If so, then you need a new switch. If not, your problem is between the fuse box and the switch.
How do you test the transmission switch, thank you.
Old November 13th, 2013, 10:20 PM
Unplug the switch. One of the two contacts on the wires running TO the switch will be constantly hot with the ignition key in the run position. Use a volt meter and check to see if you have 12v. If you do (which is my guess) you will need a new switch.
Part # AMR3918
$11.64 plus shipping from Rovahfarm
If you don't, then keep tracing the wiring back to the fuse box.
Old November 13th, 2013, 10:24 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Unplug the switch. One of the two contacts on the wires running TO the switch will be constantly hot. Use a volt meter and check to see if you have 12v. If you do (which is my guess) you will need a new switch.
Part # AMR3918
Very helpful, thanks Dave.
Old November 13th, 2013, 10:27 PM
Thats what this board is all about.
Old May 2nd, 2016, 07:33 PM
And now I'm in on this one too....no reverse lights. I'm chasing down issues all around the truck
Old June 25th, 2016, 12:02 PM
Finally got around to this - 'twas the switch. Reverse lights are back in business.
ht
Reverse light switch adjustments StphNieuw Defender Technical Discussions 2 June 18th, 2012 09:24 PM
Help! Reverse Light Switch Rosproline157 Defender Technical Discussions 4 April 30th, 2012 09:53 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Help, no reverse light Glenn_Guinto Defender Technical Discussions 7 December 26th, 2003 04:17 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
