Reverse Light is OUT. - Defender Source
Old September 8th, 2015, 09:21 AM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
This is actually on my Disco 1...but hoping a fix would be the same here as it would be on my Defender? but the reverse light used to go on when i'd throw it in reverse. then, it started flickering ... not it doesn't go on at all.
I installed work lights on the rack up top and when i turn them on, both reverse lights are tied in as well and both light up just fine. they just don't work when the truck is actually IN reverse. Need to get truck inspected before end of the month so any guidance is appreciated. thanks!
'94 D90 "HAL" & 96 Disco "Narlee"
Old September 8th, 2015, 09:36 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
NC does not require reverse lights for inspection, but then I saw you are in VA where everything on a car is illegal.
If your D1 is a manual there is a switch on the transmission that could be burned out. Also im thinking if they wont come on when your in reverse, something is breaking the circuit so I would think the reverse switch.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old September 15th, 2015, 03:27 PM
redrange's Avatar
redrange
Billy
96 Disco "Narlee"
How did you wire your work lights? You needed to wire them to get powers from the reverse switch and/or your work lights. Also, check all of the grounds.
-Jeff
not sure how they were wired... had a buddy do it. but the rev lights both go on when work lights do, so i know there bulbs are at least hooked up.
i think its the switch because the light used to work. then only worked when i pulled down hard on the gear shifter into R. now, not at all. going to try to remove the center console this weekend.
thanks again.
Old September 15th, 2015, 03:29 PM
If you need a hand, let me know, Billy. I think I'm within walking distance of your place and could be present and annoying, if nothing else.
ht
Reverse light / fog light gremlins tim Defender Technical Discussions 10 November 1st, 2014 11:26 PM
Reverse light troubleshooting loykd Defender Technical Discussions 4 August 23rd, 2006 12:56 PM
Reverse light(s) Art Vigil Defender Technical Discussions 18 May 19th, 2004 04:15 PM
Help, no reverse light Glenn_Guinto Defender Technical Discussions 7 December 26th, 2003 04:17 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
