Reverse Lamp Switch Wiring - Defender Source
Old April 14th, 2006, 05:22 PM
fleabus's Avatar
fleabus
Dan
None :(
A while ago I installed a Hella Matador light above my license plate light which is currently hooked up to my reverse lamp. Works fine....
I am planning to install Genuine reverse fog lamp switch (on steering column) so I can control on/off without having to be in reverse gear.
Question: Where do I connect the two leads from the switch?
Extra credit: How do I wire the switch so that the corresponding dash indicator illuminates when the lamp is on?
Thanks in advance for your help.
-Dan
Old April 14th, 2006, 08:28 PM
http://www.defendersource.com/forum/...ead.php?t=4863
Check out the diagrams in that thread, let me know if you need to know more.
Old April 14th, 2006, 09:01 PM
fleabus's Avatar
fleabus
Dan
None :(
Mike-
Thanks for the diagrams... but I am not sure if that is really what I am looking for.
If I understand the diagrams correctly, they are more geared for wiring up aftermarket lights (bumper lights, etc.).
I am specifically interested in knowing where the reverse light switch is activated. I would assume somewhere near the transmission. The leads from the switch I am using would need to bridge the connection to turn on the reverse light. Right?
Please let me know if I am way off.
-Dan
Edited To Clarify: I want to be able to have the reverse lamp turn on when the transmission is in reverse gear (as it works now) AND be able to turn on the reverse lamp when the transmissions is NOT in reverse gear (via the switch).
Old April 15th, 2006, 09:40 AM
Andrew Vick
Andrew Vick
95 D90
Just to clarify: aren't you using the reverse light switch now? i.e. have to be in reverse for Hella to be on?
As I understand it, you want to get away from that, go straight to a new switch, and also have the aux indicator light on the dash working. True?
Old April 15th, 2006, 11:33 AM
fleabus's Avatar
fleabus
Dan
None :(
Yes and no.
Yes, currently the reverse light only turns on when I am in reverse. There is no switch now because I tapped the Hella light directly into the regular reverse lamp wiring. When the regular reverse lamp is on, so is the Hella.
I want the reverse light to turn on when I am in reverse (as it does now) AND I want to be able to use a switch to turn on the reverse light when the trasnmission is not in reverse.
Thanks again.
-Dan
Edited to add: Yeah, the dash indicator would be cool too, but I think I need to solve the switch problem first.
Old April 15th, 2006, 12:06 PM
Andrew Vick
Andrew Vick
95 D90
Got it. Let me dig for a bit. I'm sure someone else knows it off the top of their head.
Old April 16th, 2006, 11:43 AM
OK, rather then search for the wire on the transmission most just use the hot lead off of the stock reverse light. use that wire (splice another wire in line) to power the relay to turn on the new light. To be able to turn it on at any time just add a switch someplace one end to the battery the other to the relay for the lamp.
Old April 16th, 2006, 11:58 AM
fleabus's Avatar
fleabus
Dan
None :(
Mike-
Thanks... that makes perfect sense. I wanted to try and avoid having to run a line from the steering column all the way back to the reverse light. Is there any chance someone has a wiring diagram that shows where the light from the reverse light meets the fuse panel? I assume I can do the same thing Mike suggests at the panel instead.
On to the extra credit: How do I light up the rear fog indicator on the dash when the light is on (regardless of the switch position)?
-Dan
lamp, switch, wiring
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
Need help wiring genuine fog lamp switch and Hellas fleabus Defender Technical Discussions 1 May 21st, 2006 02:00 PM
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
Reverse Lamp problem waveridin1959 Defender Technical Discussions 7 March 16th, 2004 05:46 PM
