Reverse Lamp problem - Defender Source
Old March 15th, 2004, 07:40 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I noticed the other night my reverse light wasn't coming on when i am backing up. I checked the bulb and it isn't blown. Is there a fuse to check or can it be something else?
Old March 15th, 2004, 08:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
What year is it? Check the switch. Its located on the trans with 2 wires.. Also, when you find the switch, unplug it and put the 2 wires together. If the light goes on, its the switch
Legend in My Own Mind.
Old March 15th, 2004, 10:59 PM
yellowrover's Avatar
yellowrover
Mike Holland
'97 AA Yellow D-90 ST
on my 97 d-90 the same thing happened the way they had it set up, the connection was getting covered with all the water, dirt, salt etc... that the tire kicks up, we ordered up a new harness thing and replaced the whole thing, the new kit came with a boot to protect it this time through......but it might not
Old March 16th, 2004, 12:33 AM
waveridin1959
Brian Jones
1995 D-90 ST #2892
Do I just climb under and check the wires or is there another way to access them?
Old March 16th, 2004, 08:00 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
What trans is in that/ R-380? If so, the switch is screwed into the drivers side of the trans casing. It looks like a sensor with 2 wires on it.
Old March 16th, 2004, 03:05 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
I believe I have the R-380. I will go run check the switch whenever it stops raining.
Old March 16th, 2004, 03:13 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
It is snowing like hell here. This sucks. Yesterday it was 65 deg.
Old March 16th, 2004, 05:46 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
randy, snowing here also well get 12" tonite
good luck with your search
lamp
1/USED NAS D90 (95 and 97) round reverse lamp housing-lens - $10.00 NashvilleRover For Sale - Parts 5 October 17th, 2009 09:06 PM
Reverse Lamp Switch Wiring fleabus Defender Technical Discussions 7 April 16th, 2006 11:58 AM
ZF-4HP22 reverse slipping? kiphartzell Defender Technical Discussions 0 March 20th, 2006 09:30 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
